Fuel pressure drops at wot
Old Jul 5, 2012 | 02:47 PM
moparman99's Avatar
Question Fuel pressure drops at wot
hey guys got a 99 5.9 cummins just instaled a new raptor 100gph and remote filter on the frame ive got 3/8 line from the tank to the remote filter and 3/8 from the filter to the pump with the 1/2 inch line the comes with the pump to the stock filter and i keep getting huge pressure drops a wot.i have my pump set at 20 psi and it reads that at idle but when you go to drive it the damn thing drops below 8 or so anyone have any ideas on why it would do this at all? ive checked all the lines and there all clear just dont know what to do now and dont wanna burn up another vp44. thanks
Old Jul 5, 2012 | 03:11 PM
cummin_un_glued's Avatar
FormerVendor
replace the 3/8" line with 1/2" line all the way to the tank
Old Jul 5, 2012 | 03:16 PM
biged681985's Avatar
your either need 3/8 all the way, or 1/2 all the way. going from the 3/8 to the 1/2 is where the problem is
Old Jul 5, 2012 | 03:30 PM
empty wallet's Avatar
The different sized lines aren't the problem. First problem is if you're running thru the stock line with banjo bolts from stock filter can to vp44. Second is running a filter between the tank and the raptor, it isn't needed and is nothing but another restriction.
Old Jul 5, 2012 | 04:28 PM
moparman99's Avatar
Would a draw straw do the trick with some 1/2 line from the tank to the pump?
Old Jul 5, 2012 | 07:02 PM
Draw straw wouldn't hurt. with 1/2" to pump, eliminate 1st filter, then either buy vulcan 1/2" kit for between stock filter to vp44 or make your own kit. Then you should be good. I still had pressure drops with mine so I just modded stock filter can.
Old Jul 5, 2012 | 11:43 PM
moparman99's Avatar
Thanks guys hope the draw straw and new line works
Old Jul 6, 2012 | 09:20 AM
RAW's Avatar
RAW
What kind of filter is before the Raptor? If it is just an inline strainer, it is fine.
I am running my FASS150 to my stock fuel filter, with stock lines between the filter and VP, and my pressure is very strong all the time.
Old Jul 6, 2012 | 09:31 AM
moparman99's Avatar
It's a volcan performance 3 micron frame mount filter.
Old Jul 6, 2012 | 09:36 AM
RAW's Avatar
RAW
Try putting the filter after the Raptor, not before it. 3 micron is pretty small. A 10 micron may be better if you are keeping you factory filter.
