Anybody know what this is under the dash
Old Jul 2, 2012 | 08:40 PM
reddpup's Avatar
Default Anybody know what this is under the dash
Hello I have a part under the dash that stays warm to hot all the time even when I haven't started or driven the truck does anybody know what it is or what it does? It is about 1 1/2 inches long maybe 3/4 inch diameter aluminum
cylinder in the picture. A little left of the steering column. Kinda worried about a fire it gets so hot sometimes
Attached Thumbnails Anybody know what this is under the dash-hot-piece-truck.jpg   Anybody know what this is under the dash-0702121726.jpg
Old Jul 2, 2012 | 11:11 PM
tiremann9669's Avatar
Not 100% but I think it's the flasher for your turn signals, pull it out and see if your signals still blink. I don't know why it would be hot .
Old Jul 3, 2012 | 12:15 AM
93/250's Avatar
I think the flasher for turn signals is on the fuse block itself. I was told that little cylinder is a bi-metallic strip that times interior stuff like the light around the ignition key on newer style steering columns.
Old Jul 3, 2012 | 11:34 AM
moparbubbabt59l's Avatar
Timer for interior lights the light for around the ignition cylinder
Sent from my DROIDX
Old Jul 3, 2012 | 07:36 PM
welderboy250's Avatar
I think u will find its only hot if the door has been opend or u switched on the dome light
Old Jul 3, 2012 | 08:41 PM
flyingcrodeo's Avatar
I have the EXACT same promblem and when i unplugged mine my flashers quit workin and i hadnt had my door open long or anything and its always hot too
Old Jul 4, 2012 | 11:51 AM
jdbigblue12v's Avatar
mine gets extremely hot also dont know why but it does
Old Jul 5, 2012 | 06:09 PM
CUMMINStagetcha19's Avatar
tally another. the flasher relay is on the fuse block. i burnt my hand on the cylinder when installing my tach!
Old Jul 6, 2012 | 06:18 PM
1stgenblowingsmoke's Avatar
That cylinder is designed to get hot. It's the timer for the halo light around your ignition switch it's working properly if it gets hot.
Old Jul 9, 2012 | 06:49 AM
reddpup's Avatar
Good to know that it is normal, not that excited about the design though. I believe Dodge could of done something different. I will not worry myself with the heat since everyone here says they are supposed to get hot. Thanks for all of the replies.
