New Owner!
Old Jul 2, 2012 | 08:07 PM
brianb883's Avatar
Default New Owner!
Hey everyone,
I just purchased a 2002 Ram 2500 with a 5 Speed! I've been on here alot and while I cannot do any performance mods, (yet) the truck is completely stock and only has 80,000 miles! I'll be increasing the performance a little later on, but I'd like to get any basic maintenance covered first!
I just purchased the following:
FLEETGUARD LF3894 oil filter
FLEETGUARD AF25541 air filter
FLEETGUARD FS19855 fuel filter
I plan on using Rotella synthetic to do an oil change this weekend along with all the basic maintenance.
Is there anything else I should check/look at? I've been reading about the VP44 problems, and while the truck only has 80k on it, I want to be safe, so I'm wondering what the best course of action should be.
Thanks in advance!
Old Jul 2, 2012 | 08:20 PM
biged681985's Avatar
firt mod id do is an airdog or fass. then gauges. small programmer, then clutch and injectors.
Old Jul 2, 2012 | 10:17 PM
brianb883's Avatar
why a clutch? only 80k miles, and no mods...?
Old Jul 3, 2012 | 03:25 PM
RAW's Avatar
RAW
The torque from a chip can make a stock clutch slip. Although a stock clutch can last a while if treated properly, it's good insurance to stay on the road and out of the shop unplanned.
I agree with a lift pump upgrade, even if you don't have plans of turning up the power. $500 now will save $1000+ down the road.
Old Jul 3, 2012 | 04:41 PM
brianb883's Avatar
The more ive read on the lift pumps, the more I want to get something better than the FASS DDRP pump. What would te next best pump be? And should consider a relocation kit? I agree spending money now is much better than a new vp44 however I need to be as cost effective as I can. When I do start upgrading I don't expect to be going crazy, I'll probably so an intake, exhaust, edge and an elbow to start.
Old Jul 3, 2012 | 04:53 PM
RAW's Avatar
RAW
Next best would be a FASS Platinum95, IMO. It has one filter, so I suggest running it to your stock fuel bowl. It will supply all the flow you will need, and give a little extra filtration.
Old Jul 3, 2012 | 05:35 PM
brianb883's Avatar
So when you say fuel bowl, you mean the stock filter assembly? And I guess no relocation with that pump?
Old Jul 3, 2012 | 05:44 PM
That pump is mounted on the Frame Rail and yes it deletes the stock filter.
Luke
Old Jul 3, 2012 | 07:13 PM
brianb883's Avatar
I am going To save up for the better pump then. How long could I run the stock? I'm guessing I won't for more than a month but I have to recover from buying the truck before I can put too much $$$ into it.
Old Jul 3, 2012 | 07:36 PM
RAW's Avatar
RAW
Unfortunately there is no guarantee with a VP44. Best thing to do is get a fuel pressure gauge ASAP. You don't want to see less then 10psi at the pump.
