Truck wont start!!!
Old Jul 2, 2012 | 03:03 PM
Texas-Diesel's Avatar
Default Truck wont start!! 5.9 Cummins
my truck died while driving so i assumed that it was the inj. pump, it is now replaced, key is in right everything is timed right no codes, a new sending unit and it wont start, What is going on and no i havent tested fuel pressure i just want to know if the lift pump isnt putting out enough pressure will it cause a no start? It has two lift pumps, other that its stock
Old Jul 2, 2012 | 03:51 PM
empty wallet's Avatar
did you bleed the air out of the system?
Old Jul 2, 2012 | 06:35 PM
yes, let the air out of the pump then bled each line at the head, still nothing.
Old Jul 3, 2012 | 03:26 PM
RAW's Avatar
RAW
All fuses and relays are good? Any codes?
Old Jul 3, 2012 | 03:56 PM
Yes all fuses are good and no codes
Old Jul 3, 2012 | 07:39 PM
Dodgemanstan's Avatar
Cher you are in the wrong section bud. This is for the VP44 brothers... haha
You need to be in the 03-07 section... The guys roaming that section can help ya out.
As for Texas-Diesel I would go ahead and get your self a LP cause it seems your not getting fuel. Also you still might have air in the system... You only need to bleed # 1,3,4 injector lines. The rest is overkill .
Old Jul 3, 2012 | 08:45 PM
RAW's Avatar
RAW
Thread has been moved.
doublehbar
13
Aug 9, 2015 12:35 AM
doublehbar
33
Jun 5, 2015 11:38 AM
dfish001
Mar 30, 2015 03:07 PM
mountainmover
Big Rigs & Semis
Mar 1, 2015 06:03 AM
ronstop
Feb 26, 2015 09:48 AM
