Adrenaline Comp
Old Feb 24, 2008 | 08:17 AM
Jazz's Avatar
Default Adrenaline Comp
well yesterday I tried out the comp tune on the Adrenaline. All I can say is WOW. It fuels hard, very hard. No comparison to any stack that I have run. This flat out hauls. I would bet if quad would give one out to try like they did with the smarty they wouldn't get it back This box is definitely worth it for anyone thinking about it. I know one thing for sure I won't be running around with the comp tune very often. I could drive all over with my smarty drag comp on 5x5 or smarty tst pm3 on 9 and they don't even compare to this comp tune. If you don't have a built tranny don't even attempt the comp tune. It is really hard to explain the feel of this tune. So far all is well with the Adrenaline
Old Feb 24, 2008 | 08:22 AM
Uncle Bubba's Avatar
Dammit, would you quit. I told you I don't have the money right now. Your gonna end up costin me money on the credit card if you don't quit doin this and that's not a good thing.
Old Feb 24, 2008 | 08:29 AM
Jazz's Avatar
Sorry Buddy, but you will Thank me later
Send Luke a PM now!! He still has one I think with your name on it
Old Feb 24, 2008 | 08:44 AM
I gotta sell first. I have a set a rims and tires sittin here that I took off when I put the Rickson's on, an Edge EZ and an Edge Comp that would need to go first. To much extra stuff for me to be able to justify buyin more until I move some of this first.
Old Feb 24, 2008 | 08:49 AM
Jazz's Avatar
I hear ya, I was in the same boat. I went ahead and got the adrenaline anyway. I have no self control My wife just shakes her head. Gotta Love her I sold the drag comp and tst pm3. Now all I have left is this very expensive code reader. I think its called a Smarty
Old Feb 24, 2008 | 09:10 AM
Diesel Dummy's Avatar
Come on Bubba go for it, you can take the comp and hang it from your rear view mirror!
Old Feb 24, 2008 | 09:13 AM
Old Feb 24, 2008 | 11:36 AM
cummins724's Avatar
DTR member RowJ hit the dyno with the Adrenaline Friday. Here is what he posted on DTR. Congrats RowJ!
Dynoed Adrenaline Friday night…..
OBSERVATIONS… Five Dyno Runs; all with H2O/meth on.
-Box makes an honest 183 HP and 407 ft-lbs Torque, on my CTD
-PL08 is still strongest (dyno) setting tested…. As was on V300 tune (TST Comp was #7)
-Wish I had tested PL07
-PL09 lost 21 HP/200 ft-lbs
-PL10 lost additional 1 HP but gained back 39 ft-lbs
-Surprisingly Comp Tune on PL08 lost 56 HP and 130 ft-lbs ….. Pulled smoothly and hard to 3850 rpm and felt stronger than results showed??
RESULTS…
1st Pull - ADR2000 on PL00, 415 hp / 849 ft-lbs
2th Pull - ADR2000 on PL08, 598 hp / 1256 ft-lbs, reved to red line rpm
3rd Pull - ADR2000 on PL09, 576 hp / 1056 ft-lbs, reved to red line rpm
4th Pull - ADR2000 on PL10, 575 hp / 1095 ft-lbs, reved to red line rpm
5th Pull - Comp Tune on PL08, 541 hp / 1126 ft-lbs,reved to 3850 rpm
Correction Factor = 1.1, All results corrected #’s
Old Feb 24, 2008 | 12:28 PM
Awsome numbers and thanks for the INFO!!!!!
Old Feb 24, 2008 | 01:11 PM
Bosshogg's Avatar
Ok why cant we run a smarty in a non timing tune with the adrenaline?
