Brown Line Metal Works Visit - Brown Line Metal Works
TWIN STOCK TURBOS
Old Jul 2, 2012 | 03:27 AM
ADRIAN's Avatar
Default TWIN STOCK TURBOS
i know this might be crasy but y not....an pay no mind to my spelling be on a short time frame but i have an 96 dodge cummins with the stock holset turbo ...i dont have alot of cash to dump right now but i have done many mods,,,i would like to ran a twin set up with stock turbos dont no if its possible but do any body have any ides on this an what i would have to do to get it done ...thanks
CAN ANYONE HELP PLS
Old Jul 2, 2012 | 10:41 PM
cummin_un_glued's Avatar
FormerVendor
the only way it would work is with 3 stock chargers. if your dead set on doing it try to find a second hx35 with the 12cm housing and run a pair of those as the primary stage and try to find a H1C with a 16cm turbine housing to run on the manifold as the secondary. it will work and it will support a fair amount of power but the fab work is fairly complicated and in the end a single 63mm S300 would probably suit your needs much better. if your still running the stock charger then i doubt you have more fuel then a 63mm charger would cool. if you do plan further fuel mod's then start considering putting a S471 under your stock charger because for the money you would spend on a couple used hx turbos you can buy the S400 brand new and the piping would be way less complicated.
btw wrong forum section
Last edited by cummin_un_glued; Jul 2, 2012 at 10:41 PM. Reason: Automerged Doublepost
Old Jul 4, 2012 | 01:39 PM
ADRIAN's Avatar
THANKS MAN....just wanted to c if i can make that happen cuss ive nerver seen it done i have an s400 that i got off an 97 used ..had it broke down by my buddy an waiten to put it n use...just wanted to do a stock twin setup just to be doing it
Old Jul 4, 2012 | 09:37 PM
FormerVendor
triple hx's has been done already. just go back about 3 months in diesel power mag
heavyarms
13
Mar 20, 2016 03:24 PM
06dodgecummins
Jul 13, 2015 11:24 PM
LadyyD
Chevy/GMC Duramax 2011 LML
10
Jun 1, 2015 05:30 PM
wannadrag
May 25, 2015 03:07 PM
offroad00
24
Oct 23, 2014 03:28 PM
