Low Boost 5psi Max
Old Feb 23, 2008 | 09:59 PM
LBCMS's Avatar
Default Low Boost 5psi Max
Whats the deal got everything going finally and im only getting 5psi max boost. cdr on intake is blocked no other gapeing holes that i know of. had to back off the IP flow screw so now its only one flat from its orignal setting rather then bottom out like before. what am i missing? i have the Hypermax kit on the 86 f250 6.9L
Old Feb 25, 2008 | 12:01 PM
LOGANSTANFORTH's Avatar
take some WD-40 and spray it lightly around all your connections......that will find a leak if you got one.......dont use ether cause it dosent have top lube in it.....
corksil
Aug 2, 2015 10:19 PM
soco
Jul 27, 2015 06:06 PM
chen
May 29, 2015 04:34 AM
robbyS
Apr 16, 2015 02:22 PM
cameronlee51
Oct 28, 2014 12:33 AM
