Any one near Syracuse N.Y
Old Jul 1, 2012 | 06:45 PM
Chris06's Avatar
Default Any one near Syracuse N.Y
Im in Syracuse NY and want to do an EGR delete on my 06 f350. I thought about giving it a wirl myself but not 100% sure about it. Looking for someone to or help do it. Also do i need a programer after it is done because it will throw a egr code?
Old Jul 2, 2012 | 12:19 AM
jeffa6980's Avatar
Its a really simple job and most the kits come with a step by step directions. It would take less time if you found someone near you that has done it but doing it yourself should be alright and people on here can answer any questions you have while doing it. good luck
Old Jul 2, 2012 | 08:03 AM
Mdub707's Avatar
I hate even saying I'm close. EGR delete's are the opposite of fun haha. I am close though...
You will most likely need an SCT with a custom tune that has the EGR function disabled. Typically 03/04 trucks wont throw a check engine light and typically 05+ will.
Old Jul 2, 2012 | 06:42 PM
Chris06's Avatar
The more i read and watch, I'm sure i can swing this upgrade. I'm pretty good with things, just looks time consuming. I will post when i get it done, ordering it this week. Thanks guys
Old Jul 3, 2012 | 09:34 AM
Mdub707's Avatar
It is way time consuming your first time. I think my first one or two took almost 12 hours. You will definitely want an extra set of hands around to help for sure. Things that also saved me a ton of time are having a spare intake manifold ready to go all cleaned out. Also make sure to get intake manifold gaskets. They say they are reusable, but I've found on some higher mileage trucks that they are not. They're cheap, just replace them anyways.
What kit are you going with? I went with a River City Diesel one myself, got if for $185 shipped on ebay, and I believe you can get them even cheaper now.
Old Jul 3, 2012 | 11:18 AM
Chris06's Avatar
Not sure witch kit, but thanks for the input. Love the truck. but what a pain in the *** these 6.0's are.
Old Jul 3, 2012 | 12:12 PM
Mdub707's Avatar
They're all nuts and bolts man, and if you think you're going to jump into any diesel and start modifying it and not have to touch anything, it's just not true. We have to do head studs and egr deletes, while others are doing full built transmissions just to hold a tuner... some see it as a downfall, but honestly anyone pushing any more power in ANY truck is doing studs at some point...
What else do you have done to the truck? How many miles on it? We can help you get that thing running like a top and make it RELIABLE in the mean time. A coolant filter should be at the top of your list of things to get on there too.
Old Jul 3, 2012 | 03:54 PM
Chris06's Avatar
mdub it has 178k on it. I have done all the injectors oil and egr cooler last winter, I know i should have just did this then but i didn't and kick myself now. The only upgrades are mbrp 4" turbo back, afe cold air intake and 35 toyos on 08 f350 20" wheels. I use it for work everyday its either pulling a trailer of some sort all summer and pushing snow all winter. I have had 7.3"s in the past with no problems but its a truck and its worked so I know there will be issues at some point, I just want to eliminate the common ones with it.
[IMG][/IMG]
tried to post a picture but its too big, i will mee aroumd with it later.
