Need Help Fast Truck Wont Start
Old Jun 30, 2012 | 04:32 PM
Smarty=Cummins's Avatar
Default Need Help Fast Truck Wont Start
So I just got home n left truck running grab some cloths jumped back in went 15 feet and the truck died so I bumped the key air dog will only kick on for 2 seconds n then quit. I have 2 codes p1698 n p0562 I'm lost so any help would be nice thanks
Old Jun 30, 2012 | 05:52 PM
redneck_cummins's Avatar
P1689 - No Communication Between ECM and Injection Pump Module Data link circuit failure between ECM and fuel injection pump. Low power, engine derated, or engine stops.
P0562 - Charging system voltage too low
For the p1689 check your fuel pump relay it could be bad. U could go to advance/autozone or which automotive store is closest and get a new relay and try it before suspecting its the vp44 or ecm. Hope this helps bud
Old Jul 1, 2012 | 04:24 PM
Anybody else have any idea whats wrong with it.
Old Jul 2, 2012 | 12:25 PM
Dodgemanstan's Avatar
Did you check all your relays and/or fuses? Seems to me like and electrical issue...
Old Jul 2, 2012 | 12:32 PM
Well I talked to dodge dealership n they said it's the crank shaft sensor which makes since I dont see any rpms when it turns over
Old Jul 2, 2012 | 12:56 PM
I had the same thing happen to me. I was at the store and went to start the truck up and it wouldnt turn over waited alittle while an it fired right up. Alittle ways down the road I lost my rpm guage and then it came back in bout 30 seconds. I also changed the crank shaft sensor and never had a problem since or atleast until the electronics went out on the vp.
Old Jul 2, 2012 | 02:51 PM
I have rpms when it runs but nothing when i crank it over I should see 2 hundred rpms when i crank it over
Old Jul 3, 2012 | 03:29 PM
RAW's Avatar
RAW
The Crank sensor shouldn't effect the AirDog running for such a short time though. ECM fuse perhaps, or the connections on the backside of that fuse.
Old Jul 3, 2012 | 10:29 PM
Where is that fuse at
Old Jul 3, 2012 | 10:33 PM
RAW's Avatar
RAW
Inside the cab, far left side of the dash. Door has to be open to access it. #6, I believe.
doublehbar
13
Aug 9, 2015 12:35 AM
doublehbar
33
Jun 5, 2015 11:38 AM
dfish001
Mar 30, 2015 03:07 PM
mountainmover
Big Rigs & Semis
Mar 1, 2015 06:03 AM
ronstop
Feb 26, 2015 09:48 AM
