Lift pump and fuel filter delete
Old Jun 28, 2012 | 11:27 PM
diesel life's Avatar
Default Lift pump and fuel filter delete
So i have had my airdog 150 on for about 7 months now and was wondering if anyone knows where I can get a kit to delete the stock lift pump (on the block) and the fuel filter???? It would make it look alot cleaner and have more room. I have seen them on schied diesels web site but it's not there any longer I am also gonna post this in the price quote sections...
Any info is appreciated thanks in advance
Josh
Old Jun 29, 2012 | 06:56 AM
globalwarmingcontributor's Avatar
i think you can just remove the bolts etc that hold both in place, and do away with them.. theres no delete kit, just rip it all off...
Old Jun 29, 2012 | 08:18 AM
RAW's Avatar
RAW
I agree. Remove everything and use plastic bags to cover the electrical connectors. The only thing that may give your grief is the water in fuel sensor. It would only take a resistor to confuse the ECM though.
Old Jun 29, 2012 | 08:31 AM
Ed ke6bnl's Avatar
I did have to use a space for the intake plate from what I recall. the thickness of the removed part, been a while. lot cleaner and easier access to the sensors.
Old Jun 29, 2012 | 09:27 AM
RAW's Avatar
RAW
Hmmm, shorter bolts would be necessary for the intake plate where the fuel filter comes off. Good point.
Old Jun 29, 2012 | 09:57 AM
Thanks guys just wanted to make sure before I tore into it and needed to order parts...
Thanks for the info guys
Old Jun 29, 2012 | 10:04 AM
RAW's Avatar
RAW
No problem. If you have the time, would you take some pictures and do a little write up?
Old Jun 29, 2012 | 01:55 PM
Sounds like a Good idea... I will see what I can come up with, may be a couple days before i do so but I'll get a write up on it
Old Jun 30, 2012 | 12:07 AM
wyodiesel92's Avatar
There is two bolts that you'll take out from the bracket for the factory block pump that are shorter and work perfect. I just did this last month. Removed the filter and factory lift bracket and all that. Just to save you some time finding bolts
Old Jun 30, 2012 | 10:23 AM
Thanks for the info I appreciate it
jeffersonl
Nov 15, 2015 07:35 PM
Gm3500
May 7, 2015 11:01 AM
RatsMC
May 4, 2015 05:25 PM
moneypitk5
Feb 12, 2015 11:01 AM
jeffersonl
Oct 25, 2014 06:46 AM
