Calibrating The Speedometer
Old Feb 23, 2008 | 10:25 AM
Default Calibrating The Speedometer
Two tickets and a drop in mileage, I think my speedo is off by about 7 mph. How do I fix this? Never calibrated a speedo before.
Old Feb 23, 2008 | 10:28 AM
saab9k's Avatar
Superchip programmer can fix that
Old Feb 23, 2008 | 10:38 AM
cheaper fix
Old Feb 23, 2008 | 11:41 AM
Whit's Avatar
Site Mascot
well there is the truespeed calibrator
Rickson Truck Wheels and Accessories
Old Feb 23, 2008 | 01:40 PM
Uncle Bubba's Avatar
There's at least a half dozen different brand of boxes out there that do this. The dealer can also do a flash for you that will recalibrate this.
Now I gotta ask the real question here. I see your runnin an Auto tranny, RUH ROH. How big a tires are you runnin. You know that if your speedo is off then so are your shift points on your tranny. No problem for us manual tranny guys but could be disasterous for an auto if those are off to far.
Old Feb 23, 2008 | 04:31 PM
Just put on new Dakota P265/75R16. I didn't change tire size. Tranny works, truck rolls forward and backwards.
Reflashing the computer resets for a new tire size?
Old Feb 23, 2008 | 07:24 PM
The dealer can do a re-flash to adjust the computer to the tire size you want. If they are smart enough to figure it out that is.
Old Feb 26, 2008 | 03:04 PM
Fishin2Deep4U's Avatar
Something does not add up. At what speed is it 7mph off??
What is the gear ratio and what was the tire the new one replaced?
For instance, if your speedo was correct with 245-75/16 and you went to 265-75/16 that is an increase in unloaded diameter of 3.75%. Or, at 60 MPH indicated, you would be going 62.25 MPH.
That does not account for loaded radius, ect.
If you are 7MPH, something is clearly wrong. We need more info.
Dave
Old Feb 26, 2008 | 05:20 PM
ole red's Avatar
yeah the only way to throw your speedo off is to change tire diameter or to change the gear ratio in the pumpkins
Old Feb 27, 2008 | 09:56 PM
Mopar1973Man's Avatar
Well you could use a GPS or a Scangauge II...
