48RE Shift issues
Old Jun 27, 2012 | 06:20 PM
dzzavid's Avatar
Default 48RE Shift issues
So at first my 48re was holding first gear, after i replace the gov pressure sensor and solenoid every thing was good for about 4 weeks when it developed a small output shaft leak, the fluid got low but i added it to the middle of the fill zone.
The truck will now hold first for a little bit longer than it should and will not shift into third. If i get on it and get it up too 40 then back off it will shift into 4th. Here is the kicker, when i slow down if i put the truck into Neutral for at least 2 seconds, put it back into drive it will shift all the way through the gears perfectly.
any one have any ideas on this one?
thanks in advance!
(2003 cummins 2wd)
Old Jun 27, 2012 | 08:27 PM
cerberus60's Avatar
Output shaft speed sensor. Pull it and clean the end off to see if that will help. They can get crud on them that interferes with the signal. A replacement is cheap, like $20.
Old Jun 27, 2012 | 09:55 PM
dzzavid's Avatar
Thank you for the suggestion, i will give it a try tomorrow and report back
Old Jun 28, 2012 | 10:07 PM
dzzavid's Avatar
ended up replacing the output shaft sensor for good measure, no change in the symptoms. Anything else i should try before i take it to a trans shop? thanks again. --dave
Old Jul 1, 2012 | 11:11 AM
cerberus60's Avatar
If you are not getting 3rd gear, its possible the doretc cluthc pack is burned up. Thats the way mine acted when it toasted the directs.
dwmeehan
Jan 29, 2025 12:13 PM
AKDodge
May 14, 2015 12:52 PM
EverettsGMC
Mar 29, 2015 05:42 PM
rabidrabbit
Mar 6, 2015 03:47 AM
Polaris04
Dec 1, 2014 08:27 AM
