not alot of boost?
Old Jun 27, 2012 | 05:41 PM
holset cummins's Avatar
Default not alot of boost?
hey guys. was hammering on the truck yesterday and i realized the turbo maxed out at 29 psi. i have straight pipe, waste gate blocked, and stock air box but K&N filter. i just bought a K&N e-1796 filter and going to build an air box out of sheet metal( kind of like a ice box) for it and thought that would help a psi or two but i thought i could get more out of my stock turbo. let me know.
think i have a boot leaking?
Old Jun 27, 2012 | 06:07 PM
redneck_cummins's Avatar
Sounds like you may have a boot leaking, just go through and tighten up all the clamps real good and that should solve ur problem. If it doesnt I would look toward the grid heater gaskets as they tend to leak as well and also check the exhaust manifold bolts to make sure theyre tight and check the bolts that bolt the turbo to the manifold too. As for the K&N air filter I wouldnt run it bc ur turbo will suck the oil through it and put in it ur intercooler and motor I learned that first hand. I would suggest a dry filter (AFE, AmsOil, BHAF)
Old Jun 27, 2012 | 06:45 PM
empty wallet's Avatar
What makes you think 29psi is low? You have no real fueling mods. With the edge ez that seems about right.
Old Jun 27, 2012 | 07:13 PM
biged681985's Avatar
i agree with empty. 29 psi is actually a lil more than id figure an ez would cause one to make.
Old Jun 27, 2012 | 07:15 PM
luke46's Avatar
That's about what I ran when I had small injectors and stock turbo. hx35 ain't gonna take a whole lot more anyway. One thing I didn't do at first was I plugged the line coming out the turbo but didn't know to block the waste gate. Once I turnbuckled it I got 2-3 psi or so.
Old Jun 28, 2012 | 12:06 PM
1AMatt's Avatar
Site Sponsor - 1aauto
X2 agreed with empty wallet
Old Jun 28, 2012 | 12:42 PM
thanks guys. i will go over everything just to make sure.
Old Jun 28, 2012 | 03:56 PM
RollinCoal99's Avatar
max boost for an hx35 is about 35psi anything higher starts to hurt the turbo
Un4givn
10
Apr 27, 2015 01:58 AM
ash23k
Dec 30, 2014 08:31 PM
Crews8r
Dec 21, 2014 07:35 AM
joshkhouse80
Nov 21, 2014 01:17 AM
offroad00
24
Oct 23, 2014 03:28 PM
