still have rpm,s bouncing
Old Jun 27, 2012 | 05:09 PM
russellflemister's Avatar
Default still have rpm,s bouncing
my rpm,s bouncing around on my 99 dodge cummins well i did change the TPS sensor and crank sensor it did not solve the problem would you have any idea of what i should check next other then that truck runs great if i hit the throttle pettle while the rpm,s bounce up and down it will stop injectors are only a year old 100hp bd injectors
Old Jun 27, 2012 | 06:10 PM
redneck_cummins's Avatar
I have the same problem and Ive come to just accept that its normal. The only way I could get them to stop bouncing was to use the smarty and set the injector duration to level 6. Hope this helps bud
Old Jul 2, 2012 | 04:20 PM
got it fixed changed tps
