Egt question
Old Jun 27, 2012 | 04:03 PM
redneck_cummins's Avatar
Default Egt question
I had a htpm exhaust manifold on my and had my egt probe in the port hole toward the front since I didnt have a way to use the back port. Well I had to remove the htpm manifold bc it was leaking at the front joint were it was pressed together and I put my factory one back on. My question is when the probe was in the front hole of the htpm manifold the egts runned alittle cooler and now that its in the factory manifold which its been drilled at the bank for 4,5,6 and now its running hotter and I was wondering if I couldve done any damage to the truck? I took it for a test drive an just driving it normal it would be upwards toward 700-800 and when I got on it hard it would climb toward 1200 quicker than with the other manifold. Should I be worried about it or is this just normal?
Thanks
Old Jun 27, 2012 | 04:14 PM
Smarty=Cummins's Avatar
Thats a good temperature to run at wot. Mine runs up to 1450.
Old Jun 27, 2012 | 04:22 PM
Ok thanks smarty I figured it was probably ok just wanted to make sure
Old Jun 28, 2012 | 12:05 PM
1AMatt's Avatar
Site Sponsor - 1aauto
1200* is actually pretty dang good!
Old Jun 28, 2012 | 04:55 PM
Does anybody know what the degree temp difference is between cylinders 1-3 vs 4-6? Ive always heard an read that 4-6 run alittle bit hotter but how much hotter?
torg73
May 11, 2015 03:08 AM
TurboBoy6.5
Apr 12, 2015 11:22 PM
Brappp306
Mar 29, 2015 08:54 PM
97 stroker
Ford Powerstroke 08-10 6.4L
Feb 18, 2015 03:25 PM
scottxmorris
Nov 11, 2014 03:28 PM
