pump mods on hybrid turbo
Old Jun 26, 2012 | 10:15 PM
NauticaEE's Avatar
Default pump mods on hybrid turbo
ok fellas i have a 96 12v, i just did a hx35/hx40 hybrid on it and 4k gsk, the engine was just built and does have o rings and studs, my turbo has no wastegate, and i was wanting to run no plate and i have a rack plug on the way, my injectors as of now are stock, my question is what other mods should i do to my pump? will adjusting the afc and starwheel benefit me any? thanks for any help!
Old Jun 26, 2012 | 11:51 PM
turbo2332's Avatar
adjusting the afc will help but your hybrid is close if not already over fueled. running the thing with no gate drastically shortens its operational life span. you should without a doubt make the wastegate operational!!! the fuel plate is a tuning device. yes you can make a bit more power without one but you loose that ability to tune. i personally dont rcommend to anyone running plateless on anything.
Old Jun 27, 2012 | 10:53 PM
NauticaEE's Avatar
ten four, thanks for your reply, will def get the gate going!
ctjkelley
Jun 3, 2015 06:01 AM
Gm3500
May 7, 2015 11:01 AM
Ian Roberts
Mar 23, 2015 12:36 AM
moneypitk5
Feb 12, 2015 11:01 AM
D-350 dually
Feb 6, 2015 05:41 PM
