Major Trans Problem….
Old Feb 22, 2008 | 01:51 PM
xzaq103's Avatar
FormerVendor
Default Major Trans Problem….
I have a major problem with my truck. It started last night I came to a coast and the go back on the throttle and at about 15 mph it felt like the TC locked up and lugged the engine. I shifted to neutral and it quit then I went back to drive and it had no problem. And I drove on home. Today on my way to work I came to a stop after getting lunch and it did it again but this time after the going to neutral and back to drive it did it again about 6 more times till I got to work the last time it killed the engine. So I stuck it into 4 LO and let it idle to a spot. About 30 minuets later I got back in it and went for a spin with no trouble. Any ideas? The trans is completely stock at least to the best of my knowledge. I was saving for a built trans may be getting it a little sooner tan I thought
Chris
Old Feb 22, 2008 | 02:03 PM
DB Admin's Avatar
Banned
Dont sound good thats for sure , Sounds like Major Tranny Issues Best Call a shop to get er' in there
Old Feb 22, 2008 | 02:06 PM
DangerousDuramax's Avatar
Sounds like your TC is staying locked or your valve body is having an issue relieving line pressure on the down shift. Get it to a shop.
Old Feb 22, 2008 | 02:22 PM
xzaq103's Avatar
FormerVendor
Thats what i was thinkng staying locked up. The call to DTT confirmed what i was thinking . No i just gotta pic a trans company what do you guys think. im leaning towards Goerend or hts but i still like DTT.
Chris
Old Feb 22, 2008 | 02:24 PM
DB Admin's Avatar
Banned
Ive rode /Driven Each I really liked the Goerend
Old Feb 22, 2008 | 02:29 PM
xzaq103's Avatar
FormerVendor
Thanks DM
Old Feb 22, 2008 | 02:32 PM
DB Admin's Avatar
Banned
The 06 PSD i drove was the best , Almost like a Hydro Static ,
The Suncoast is Quite Violent , the Goerend is alot Smoother and there customer service is better
Old Feb 22, 2008 | 02:41 PM
The difference in shifting depends on the level of build and the programming. My truck shifts so hard it'll knock your teeth out because its built for racing. A smoother shifting tranny is built for daily driving and towing. The shifting depends on how you want it built.
Old Feb 22, 2008 | 02:42 PM
DB Admin's Avatar
Banned
3 x +500 HP trucks with 3 Built Trannys and the Goerend Was Twice as smooth as the others
Old Feb 22, 2008 | 02:46 PM
Probably had a tow converter and not a race converter. I've seen the Goerend's race truck make some laps and it shifts hard as hell.
