Replaced fenders, now won't shift from first?!
Old Jun 24, 2012 | 05:13 PM
Obee's Avatar
Default Replaced fenders, now won't shift from first?!
Hey guys, recently replaced my rusty front fenders for some rust free fenders but now the truck will not shift out of first gear, any ideas? It has first gear and reverse.Truck is a 2000 24v ext. cab with Auto tranny. Will not shift on its own nor if you help it by doing it.. Checked for bare wires but did not see anything. Any connections I may have missed that would cause this? All works as normal but will not leave first.
Also checked for codes and it shows (P done). No codes at all.
Getting frustrating as i drove the truck home last week with no worries, parked it for 3 days while i did the fenders and now all of a sudden it is acting up. Changed out my Tranny Relay with no luck. Any help is greatly appreciated.
Old Jun 24, 2012 | 08:53 PM
wyodiesel92's Avatar
Sounds like a ground maybe. There are quite few grounds that are either on the fenders or right by them
Old Jun 25, 2012 | 06:34 PM
Obee's Avatar
I removed 3 grounds from the fenders in total. 2 on the drivers side at the front by your headlight bracket. Two studs with 1 Ground to each coming from a thick harness. New fender did not have the studs so they are grounded with self tappers into the fender. Third was on the passenger side from my battery ground over to my fender. Any others i should look for? Or what would those 2 grounds on Drivers side fender be for?
So looking further I believe my tranny output shaft speed sensor is buggered. Anybody run into this before?
Old Jun 25, 2012 | 08:01 PM
Sarafin's Avatar
That sounds extremely plausible. You could also try sanding down where your grounds are and reconnecting.
best of luck
-Sarafin
Old Jun 25, 2012 | 08:13 PM
Paint under the ground can render them useless or lacking, I'd start with the grounds and then fix the speed sensor
Old Jun 26, 2012 | 01:15 AM
tht77's Avatar
My 2000 threw a code when the output speed sensor went bad. It did the same thing but if I unhooked the battery cables for 10 minutes it would shift for 15 or so minutes. Hope you get it figured out. Good luck.
Old Jun 26, 2012 | 03:40 PM
photomonkey's Avatar
Ground issue... what wyo and sarafin said +1...
Sand them down and reconnect. Bare metal!!
Old Jun 27, 2012 | 09:46 AM
Obee's Avatar
Replaced the sensor and all is good again! Thanks for the help guys!
cummins1999
Jun 26, 2015 01:56 AM
AKDodge
May 14, 2015 12:52 PM
EverettsGMC
Mar 29, 2015 05:42 PM
rabidrabbit
Mar 6, 2015 03:47 AM
pappyscrapster
Feb 18, 2015 09:44 AM
