Oil system contamination
Old Jun 24, 2012 | 11:04 AM
Island Diesel's Avatar
Default Oil system contamination
I looked at a 2006 truck that won't start. The owner said the dealer changed the LPOP due to failure and was told that the contamination migrated into the high psi system and has contaminated and ruined the injectors. If you watch desired vs actual icp it reaches 1500 psi at about 30% duty cycle on the IPR telling me the high psi system is healthy. Is it possible for the contamination to migrate that far? FICM voltage is 48.5v and the FICM goes into sync and you can hear the injectors pop.
Old Jun 26, 2012 | 07:41 AM
Mdub707's Avatar
Sounds like the high pressure oil system is working ok!? When the truck is turning over is there any smoke coming from the exhaust?
Durtyd09
Nov 11, 2015 01:43 PM
vin_diesel
Sep 15, 2015 11:25 AM
soco
Jul 27, 2015 06:06 PM
LTreis702
Feb 14, 2015 12:52 PM
coors_man_2005
Dec 15, 2014 10:23 AM
