Need 6.0 wiring diagram
Old Jun 22, 2012 | 07:48 PM
Altonlee's Avatar
Default Need 6.0 wiring diagram
Hi I have a 2004 ford f350 with early 6.0. Just bought the truck and was told it had bad hpop. Replaced hpop-egr delete-icp and irp.
after I got it back together will not start code says lost comm with inject contl mod code u0105 and u0306 sftwr incompatable injector contl mod.
Ran the tes on the ficm only get 8 volts. Got the full 48 before replacing all this. Best I can figure is I broke a wire some where. Have checked all connections and they are tight.
Now I need a wirging diagram to help run it down.
Thanks
Old Jun 22, 2012 | 08:47 PM
jeffa6980's Avatar
maybe you knocked something loose inside the ficm and now it isnt working. do you have anyone around you with a similar truck that you can swap the ficm out with to see if it works
Old Jun 22, 2012 | 09:03 PM
bobfbigman's Avatar
Also make sure the ground is on from the injector harness, think it goes on the lat inside bolt of intake. Check the connection at fenderwell on drivers side, it ties the ecm to the ficm. will post a link for wiring but don't know if its going to help.
Powerstroke 6.0L Technical Intro Manual
Lilpooh's Avatar
Check all your ground cables (batteries, engine) even the one for the FICM that gets bolted to the rear intake manifold bolt/stud.
Old Jun 22, 2012 | 09:04 PM
Lilpooh's Avatar
Dang Bob, you were a split second before me! LOL!
Old Jun 22, 2012 | 09:07 PM
bobfbigman's Avatar
now thats funny.
manns999
19
May 3, 2024 01:40 PM
slowstroke
For Sale
Apr 1, 2015 11:35 AM
scubasteve12
Mar 29, 2015 09:39 PM
NaturesPace
Dec 16, 2014 12:01 AM
12valve_soot
Nov 12, 2014 10:02 PM
