air conditioning problem
Old Jun 21, 2012 | 06:16 PM
Lethal's Avatar
Default air conditioning problem
2006 fordf350 6.0 have an air conditioning problem. Runs good when idling goes in and out when driving down road.
Old Jun 21, 2012 | 07:13 PM
Karls03's Avatar
If you use the search you will see that I asked this on Sunday (4 days ago) and nobody responded.
Through my own research I found that the likely suspect is a faulty high pressure switch that is located on the compressor.
Mine must have been a circuit breaker that reset itself, Sunday, grounded battery (oops) no ac above idle, Monday going home from work, normal ac.
Old Jun 24, 2012 | 06:14 AM
94.5powerstroke's Avatar
We just had the same problem we had to cange the hole compressor the. cluth was going bad when we would put it under pressure the cluth would disengage
Old Jun 24, 2012 | 01:14 PM
allen2289's Avatar
I would put a set of gauges on it and check the pressures we have a ton of problems out of the low pressure switches on the trucks we have at shop.
burndiesel
10
Feb 7, 2023 01:15 AM
carid
Diesel Bombers Sponsors
May 27, 2015 07:01 AM
robbyS
Apr 16, 2015 02:22 PM
moneypitk5
Feb 12, 2015 11:01 AM
