Differential Additive / chatters when making tight turns
Old Jun 21, 2012 | 09:44 PM
Crackshot's Avatar
Default Differential Additive / chatters when making tight turns
Did a fluid change on rear diff and put 4 ounces of LSD additive in there.
Filled the axle and chatters making tight turns. (I obviously need another bottle in there)
My question is, being I filled the pumpkin until it dripped out of the fill hole, if I suck some gear fluid out, should just suck out 4 or so ounces worth and add another 4 ounces?
Reason I ask is because now that the 4 ounces I added is mixed in the gear fluid, is 4 more ounces going to be enough if I suck out some fluid?
fixed it. added another 4 ounce bottle and good to go.
Old Jul 24, 2012 | 04:37 PM
Mike337's Avatar
You sure the spider gears are not broken?
Old Jul 24, 2012 | 08:25 PM
Crackshot's Avatar
I added another 4 oz to it and the chatter went away.
I guess it needs like 7.5 to 8 from other boards I have been on.
Works great now! Thanks for reply!
PowerStrokin94
Mar 21, 2015 07:15 PM
