Engine electronic Problem
Old Jun 20, 2012 | 08:04 PM
RegansDiesel's Avatar
Default Engine electronic Problem
Hey Everyone i looked up my industrial 2002 Cummins on Cummins Quick Serve and it is in fact a standard output and not a high-output. However, I have a highout put ECM and my engine runs funny at an idle after i press the pedal. I loaded a video of its symptoms. Is this what you guys have seen when there is a high out put ecm on a standard engine without the high compression pistons, and different vp44?
Old Jun 20, 2012 | 08:25 PM
empty wallet's Avatar
Interesting... any codes? I know for a fact HO and SO vp44's can be swapped back and forth without side effects. I also know the compression ratios are different in the 2 and who the hell knows how the ecm's vary, I doubt anybody on here will know for sure, but the best thing I can think of is get an SO ecm.
Old Jun 20, 2012 | 09:04 PM
Hey Empty Wallet,
Thanks for the help man. Only code thrown is P0341 about the cam sensor and replaced it and code doesn't go away. I might bypass harness and solder directly to the wire coming off ECM i have a diagram and I will continuity test it to make sure i have the right one. I think this could be an APPS issue also making the idle validation go from throttle to idle throttle to idle. I believe i will for sure get it re-flashed so later down the road i wont have any problems with everything matching.
burndiesel
10
Feb 7, 2023 01:15 AM
jeremy01995
Sep 14, 2015 06:34 PM
klein444
Jun 20, 2015 11:48 PM
metal_miner
Diesel Engine Conversions
Dec 23, 2014 11:40 PM
hunt4beer
Nov 15, 2014 09:06 AM
