Tire Separation
Old Jun 19, 2012 | 01:04 AM
gonza's Avatar
Default Tire Separation
I have a 2001 GMC 2500HD 4X4 LB7 with the 6 speed manual trans that my back tires started to separate on our last trip with our 32ft 5th wheel toy hauler (Forest River Sandstorm). The tires are Hercules All Track A/T Load Range E tires. I rotate every oil change and have good even wear and all ways add air up to max 80psi when pulling the trailer and deflate back to 45psi unloaded. I have never had this issue before, any suggestion why, I'm thinking I need to put air bags on the truck to get more weight transferring back on to the trailer. We only have had the Sandstorm for a year and the tires for around 2 (our first RV), any thoughts?
Old Jun 19, 2012 | 03:07 PM
dmaxjenn's Avatar
IT'S A GIRL!
make sure your tires pressure isnt over inflated,usually the cause of seperation.. use the tire pressure specs on the side door of the truck, how many kilometers on the tires? there life span is around 80ks..just keep in that in mind.
Old Jun 22, 2012 | 07:03 PM
gonza's Avatar
I checked the specs on the door and 80psi for the rear.
B737 Capt
Jun 9, 2015 06:34 AM
dallasca
28
May 26, 2015 12:58 AM
LB7yooper
Chevy/GMC Duramax 01-04 LB7
Mar 23, 2015 11:33 AM
Supremedragonx
Mar 1, 2015 01:50 PM
veggyoilkid
Tire, Wheel & Suspension
Nov 5, 2014 01:34 PM
