Red October
Old Jun 18, 2012 | 11:57 AM
cjmatherson's Avatar
Default Red October
I run red fuel. Have for ever. Plus sometimes motor oil. The truck is 97 12v. Never had any prob. Now I got problems. When under 1500 rpm driving runs fine if you get on it it will slowly loose power if you keep the pedal down you get some popping and white smoke . I can dry rev the motor and around 2k as its building rpms it pops and some white smoke but it will stay at 2800r with no issues. It feels like its running out of fuel when its driven on the road. New air filter new fuel filter. Pulled tank and took a very nasty screen off bottom of white tube but I noticed another filter in the white tube thought it may still be good probly not. Any other things i can check before I pull tank again
Old Jun 18, 2012 | 04:13 PM
cumminstothefloor's Avatar
Sounds like it could be a tired over flow valve.
Old Jun 18, 2012 | 04:52 PM
is that in the p-pump. i dont think its the fuel cuz i've ran hydro fluid tranny fluid peanut oil motor oil for years and havent had any issuses is there a way to test the overflow vavle? does the pump have to come off to sevice that part. thanx for the knowlegde.
Old Jun 18, 2012 | 05:48 PM
Its in the injector pump. Its pretty much a banjo bolt with a small metal ball and spring in there. Over time the spring gets worn and allows fuel to pass through meaning you'll loose fuel pressure. I've read that people change them for preventative maintenance. Heres a pic of what it looks like and location:
There is a trick you can do to diagnose weather or not this is still good. It is said you can take a spring from a ball point pen, take the ofv apart and slide the extra spring inside the original (assuming this will stiffen the worn spring back out revitalizing fuel pressure) Never done it tho and don't plan on it so I don't know if it works. You can order a new one anywhere from 50-100 bucks.
There is a thread open below on fov you can pick up some more info on the topic.
Last edited by cumminstothefloor; Jun 18, 2012 at 05:48 PM. Reason: Automerged Doublepost
Old Jun 18, 2012 | 05:51 PM
look who's the ****** man. thanx you couldnt of made it easier. i'll check it right now
Old Jun 18, 2012 | 06:02 PM
Anytime man!
Old Jun 18, 2012 | 07:33 PM
Diesle Bombers number 1 runs great. pen spring i got so much fuel on me yesterday cuz I didnt ask a bomber first but as always you guys come thru
Old Jun 18, 2012 | 07:58 PM
So that was the problem? I didn't understand that
Old Jun 19, 2012 | 12:22 AM
Yep thanx
Old Jun 19, 2012 | 04:10 AM
sweet. glad it was something simple
tbreddiesel
Thoroughbred Diesel
Oct 2, 2015 02:56 PM
tbreddiesel
Diesel Related Events
Oct 2, 2015 02:55 PM
Dec 9, 2014 07:40 PM
Nov 1, 2014 08:20 AM
