maybe a 97?
Old Jun 17, 2012 | 05:20 PM
CMCA Swartzkrautheim's Avatar
Default maybe a 97?
alright so my truck is in my sig BUT the diesel that made me fall in love with diesel was a 01 cummins, i may be able too trade my truck for this one strait up what do you guys think AND what problems should i look for if any???
This is the truck...
FULLY BUILT CUMMINS!! Sell/trade
Old Jun 17, 2012 | 05:30 PM
1999stroker's Avatar
I seen that I live in cincy Ohio. Idk anything over 250,000 scares me
Sent from my dumb phone!
Old Jun 17, 2012 | 05:52 PM
daveO's Avatar
IMO, a truck already modded that far has probably been beat on. Also, if it does have firerings like he says, and not o-rings, I'd stay away from it. Fire rings aren't very good for a street driven truck, they can't handle the amount of heat cycles. Not to mention, 400k+ miles is a lot for a truck, even if it only has 190k on the motor.
Old Jun 18, 2012 | 11:26 PM
it was built by hallas performance local diesel hero for ford guys but he dont mess around with anything he does so i DO know it was done right i just didnt really know what to look for on the cummins
well i looked at it today and holy crap does it smoke, it needs a bigger or maybe an extra turbo...or 2... not in too bad of shape got a leak from the hydro boost or somewhere around, is there a common spot for em to leak?
Last edited by CMCA Swartzkrautheim; Jun 18, 2012 at 11:26 PM. Reason: Automerged Doublepost
Old Jun 19, 2012 | 09:06 AM
turbo2332's Avatar
there is no way that truck is at 575HP!!!! maybe the low 400's that charger is just a tickle bigger than stock. full cuts in lots of cases loose you power. 150 injectors are prolly 5x14's or 5x16's which is WAY to big for that charger. 5x12's are PLENTY for a stocker or a super B. there is no mention a an aftermarket fuel system which is absolutly needed with big injectors and DV's! i would run away from this truck as fast as you could. if it was in the 5k range maybe but not at this price. get a truck with 150k on the clock for a price like that. RUNNNNNNNNNNNNNNNN!!!!!!!!!!!!!!!!!!!!!!!!!!
Old Jun 19, 2012 | 11:56 AM
its possible trade for my stroke, no way id pay 10 for it bodys not perfect, if i got it what size turbo should i look at and whats the diff with the dvs? i know its a delivery valve but construction mechanic A school for me was a couple of years ago not havin a fuel system do you think that may have hurt the ppump??? ill have to check if hallas doin the rest im sure he did...
Old Jun 19, 2012 | 12:24 PM
turbo2332's Avatar
yes with the size of injectors and dv's the pump IS running very close to dy with a stock lift pump. and full cuts dont have a shoulder on them so they dont stop the fuel flow when fuel needs to be stopped. lots of wasted fuel and excessive heat. if this truck is put together the way it seems to be i wouldnt trust it for anything. a turbo upgrade is gonna run around $1500 a stock turbo is good for around 350 HP which is plenty to have fun in. they are 56/58/12's vrs this 58/61/??? very very minimul gains to be had there. this truck seems to be a kids dream of blowing smoke. and it has 400,000K on it its wore out. keep the stroker and keep lookin.
Old Jun 20, 2012 | 03:18 AM
alright FINNNNNEEEEE i dont mind, i found out its time for a reburn after doin my injectors in my truck so i got some new found power WITHOUT my chip so im havin fun with it anyhow thanks guys i really appreciate all the help!
Old Jun 21, 2012 | 01:34 PM
1AMatt's Avatar
Site Sponsor - 1aauto
Agreed... Trucks that are that built usually are beat. But 10K doesnt seem too bad
