I wanna go fast
Old Jun 17, 2012 | 04:45 PM
buckstrucks's Avatar
Default I wanna go fast
Hey guys! this is my 1st post ever! i need your guys expert opinions on a couple things.
I have a 1991 non i/c 4x4 truck with the getrag 5speed, 4in lift with 35in muddys and 4:10s, i have my pump turned up almost to runaway, my fuel cone turned, and my smoke screw turned in two turns, and the AFC Star Wheel Adjustment turned in, and a couple 2in holes in my air box.
After i did all the adjustment to my pump the truck pulls way harder than it did, i live in the high sierras of northern California and i rarely have to down shift because of a hill, and there is some pretty steep grades. I was happy with the pump tuning for a while but now i need more.
I want to upgrade my turbo my baby H1C has a lil more shaft play than i am comfortable running, i rarely tow anything heavier than a fish boat and a couple dirtbikes. So i want to make my 12v bad lil hotrod. I already have my pyro and boost gauges.
So i don't know what turbo to run, i want to make more boost than the H1c but how much boost is ok before i have to start worrying about head gaskets? Or is it ok to just re torque my head bolts?
Im thinking about ordering the dennyt stage II pin and a 366 spring.
i understand that the non i/c rigs have bigger injectors than intercooled, but are they big enough after i upgrade my turbo??
Let me know what u guys would do please!!!
Old Jun 17, 2012 | 08:35 PM
firstgenfreak93's Avatar
I would see if you could do a swap to an hx35 off of a second gen cummins. That might supply the power and boost levels you are looking for.
Old Jun 18, 2012 | 02:53 AM
JasonQuartermile's Avatar
I can walk you through 300-900rwhp, depend on money and what you're willing to deal with (water-meth, nitrous, etc). Big Power is 5-6K with bottle, everything else will be cheaper.
Old Jun 18, 2012 | 02:09 PM
1STGENFARMBOY's Avatar
non intercooled injectors will fuel way more than an HX35 can cool, an HX35 is not much of an upgrade unless it's free.
Old Jun 18, 2012 | 05:40 PM
jdbigblue12v's Avatar
try to pick up an s300 turbo you will be pretty happy with it or maybe a phat shaft 66?
Old Jun 18, 2012 | 10:21 PM
AHineman's Avatar
Old Jun 19, 2012 | 02:40 AM
1stgenblowingsmoke's Avatar
Yeah good luck spooling that on stock non ic injectors.
A Intercooler will be a BIG help as well as keep her running cooler. Also if you havn't do a timing bump you will like that and a smaller exh housing like a wg 14 or non wg 16cm.
Last edited by 1stgenblowingsmoke; Jun 19, 2012 at 02:40 AM. Reason: Automerged Doublepost
Old Jun 23, 2012 | 12:42 AM
That93Guy's Avatar
You got some videos of this beast of yours? I wanna see some proof! Not that I don't believe you, I just think proof would be fun!
Old Jun 23, 2012 | 07:03 PM
AHineman's Avatar
There's his truck.
Old Jun 25, 2012 | 01:44 AM
Before it got painted:
On the track, one stage at half track....
jimmer4dat
Sep 9, 2015 06:08 PM
stevenb86
Mar 8, 2015 10:02 AM
