Egt question
Old Jun 16, 2012 | 07:16 PM
06carli's Avatar
Default Egt question
Just curious what everyone's egt's run.
Where is your probe located at?
Egt at idle?
Egt cruising unloaded?
Egt loaded?
Discuss.......
Old Jun 20, 2012 | 11:21 PM
JimmyT's Avatar
At idle i'm around 300deg
Unloaded going down a strait road around 600deg, if i'm getting on it up a hill around 800
Towing, i try and keep it below 1100deg
this also depends were you have your sensor. i cant remember but i think it runs colder after the turbo and hotter before the turbo.
Old Jun 22, 2012 | 12:00 AM
Gerry R's Avatar
Default EGT's
On the older 24v engines the best place for the sending unit most agree on is in the middle of the exhaust manifold between cylinders 3 & 4 but with common rails most that I've read put them between 5 & 6 as this apparently is the hottest. My values are common with those previously stated. Also ambient temps will have some effect I've found. Most don't feel that post turbo is a good idea because there is a big, as in 300* difference. I'd rather know what the actual temp is right after combustion.
Old Jun 22, 2012 | 01:19 PM
JimmyT's Avatar
Yeah i definetly agree, i wish i put mine between 5 and 6. But atleast i got somewhat of an idea what the temp are. I plan on buying a different exhuast manifold eventually with the adaptor already on it.
Old Jul 17, 2012 | 06:48 PM
s10driver85's Avatar
Im 300 when idle, 600-900 on highway, and I lift off the throttle when I hit 1200 while towing,( mostly when pulling a pass high elevation and hphot outside) that's the only time I get that hot, I put my prob right about the turbo
torg73
May 11, 2015 03:08 AM
TurboBoy6.5
Apr 12, 2015 11:22 PM
Brappp306
Mar 29, 2015 08:54 PM
97 stroker
Ford Powerstroke 08-10 6.4L
Feb 18, 2015 03:25 PM
scottxmorris
Nov 11, 2014 03:28 PM
