Brake question
Old Jun 16, 2012 | 01:02 PM
Crackshot's Avatar
Default Brake question
New user here!
I have a 98.5 cummins 24V.
The brake seem rock hard. I can stop but have to apply a lot more pressure than my 1500 gasser.
I know these run off the PS pump. Any easy way to quick test booster?
Also what kind of PS fluid should I use in it?
Thanks!
Old Jun 16, 2012 | 03:22 PM
peters0756's Avatar
Check the owners manual and the p/s dipstick for oil type. Check the color of the fluid and condition, does it smell bad, brown, or burnt? You could try flushing the p/s system fluid as well. Check for oil leaks around the booster at the firewall and look inside under the dash where the push rod comes through. See if there is any oil there or running down the firewall. After that there isn't much you can do on your own. Hope this helps.
Just thought of something else. If there is a rubber pressure hose between the pump and the booster then you could try to disconnect it and check the flow to the booster. Old hoses can deteriorate and act like a one way valve but I would do that last.
Last edited by peters0756; Jun 16, 2012 at 03:22 PM. Reason: Automerged Doublepost
Hogridenfool
Nov 20, 2017 04:37 PM
weatherby
Aug 31, 2015 08:04 PM
Turbo67
Jul 25, 2015 02:26 PM
Rcracer78
Audio Equipment/Electrical
Apr 20, 2015 12:49 AM
yams
Nov 29, 2014 09:25 PM
