Ignition Switch OFF Engine continues to Run 24v 2001
Old Jun 16, 2012 | 11:02 AM
BloodyDuck's Avatar
Default Ignition Switch OFF Engine continues to Run 24v 2001
I have a 2001 Cummins 2500 24v 235HP. When I shut off the Ignition the engine keeps running. Could this be the ASD? or the ignition switch? or ???..I need some troubleshooting guidence. Thanks for your help.-sam
Old Jun 16, 2012 | 05:35 PM
Baradium's Avatar
Does this truck have any mods or changes whatsoever to the electrical wiring?
Old Jun 17, 2012 | 05:41 AM
BloodyDuck's Avatar
IT HAS THE EDGE COMPUTER/TUNER INSTALLED. I BOUGHT THE TRUCK WITH 121000 MILES AND IT NOW HAS 132000. I HAVE HAD NO PROBLEMS WITH THE TRUCK. OVER THE LAST MONTH I HAVE NOTICED THAT THE MOTOR TOOK A SECOND OR TWO TO SHUT DOWN AFTER CUTTING THE IGNITION SWITCH OFF. THANKS FOR THE REPLY.-SAM
Old Jun 17, 2012 | 06:41 AM
Cook's Avatar
I would unhook the edge and see if it continues to do it. Quick & easy to rule it out of the equasion.
Old Jun 19, 2012 | 06:21 AM
BloodyDuck's Avatar
Thanks for the reply. I pulled the Automatic Shutdown relay to stop the engine and removed the battery cables. The cleared up the problem for now. I am not sure if it was the ASD or the removal of power to another system that did it.
Old Jun 21, 2012 | 08:24 PM
DieselObsession76's Avatar
Doesnt Edge have a turbo timer???
Old Jun 22, 2012 | 09:00 AM
ducktape's Avatar
edge has a egt turbo timer to get the egts down before shutting off. its adjustable or maybe it could be the fuel shutoff solenoid???
Old Jun 22, 2012 | 08:44 PM
Macarena Man's Avatar
Put your foot on the brake while you turn your key to off .....
Mine does the same thing .... has Edge /Attitude ....it might be a safety feature.
Old Jun 26, 2012 | 07:30 AM
BloodyDuck's Avatar
I tried putting my foot on the brake when shutting down...no help...the problem is intermittent... and happens once out of 9 or 10 shutdowns... thanks for the input guys....
Old Jun 26, 2012 | 07:40 AM
RAW's Avatar
RAW
Have you tried swapping the relay with a known good relay, or just replacing it?
