Horrible Clicking Sound
Old Jun 15, 2012 | 01:52 PM
SRTcummins's Avatar
Default Horrible Clicking Sound
Whenever i turn my a/c or heat on i get this horrible clicking noise like the a/c clutch is getting engaged and then the rpms drop a bit (it sounds like you put it in drive but your in park) then you hear the click again and the rpms come back up and it sounds like a normal idle again.
Old Jun 15, 2012 | 02:20 PM
RAW's Avatar
RAW
Most likely low refrigerant, causing the clutch to cycle. Does it do it on vent mode, A/C should not run on that setting.
Old Jun 15, 2012 | 02:28 PM
SRTcummins's Avatar
oh i forgot to mention that it all started happening after i put new refrigerant in! and it does it even when i turn defrosters on...basically whenever the fans are spinning
Old Jun 15, 2012 | 02:29 PM
RAW's Avatar
RAW
That seems odd, A/C shouldn't run in vent mode. It does in all others though. What kind and how much was put in?
Old Jun 15, 2012 | 02:31 PM
SRTcummins's Avatar
the whole can ( it was completly empty) and it makes the noise when i turn the heat on,i wont even touch the a/c. if i can ill post a video
Old Jun 15, 2012 | 02:35 PM
RAW's Avatar
RAW
One of those small 6oz cans? The system requires 2lbs, which is over 5 of those cans.
Old Jun 15, 2012 | 06:36 PM
Baradium's Avatar
It sounds to me like you should take it to a shop with the correct equipment to correctly fill the system on your truck.
If it was actually completely empty to no pressure, you may need a new filter/dryer as well.
Old Jun 15, 2012 | 08:03 PM
Whit's Avatar
Site Mascot
you say the system was empty, if you opened the closed system it will need to have a vacumn pulled on it before ya can add the refigerent
Old Jun 26, 2012 | 05:38 PM
photomonkey's Avatar
That happened on my truck in both underfill and OVERfill conditions. Time for professional vacdown.
Old Jun 26, 2012 | 06:35 PM
ducktape's Avatar
whats your low side pressure at running the compressor and when not?
GT_Eleanor
Aug 24, 2015 12:11 AM
mpmcbride42
Apr 7, 2015 08:28 PM
Kooper
Jan 11, 2015 08:52 PM
dutchsupreme
Dec 18, 2014 01:44 PM
JonW
Dec 10, 2014 02:44 PM
