47RE test ports/temp gauge question
Old Jun 11, 2012 | 04:09 PM
JBearSVT's Avatar
Default 47RE test ports/temp gauge question
Got my Isspro's, and my trans hot line doesn't have the T fitting to screw the sensor into. From my homework here I've found that most people cut the hard line and instal the fitting, or buy a new line with it already there. I reeeeally do not want to do either of these if I don't have to. I've also read that you don't want to instal the fitting in the soft line either, which I wouldn't mind so much but not if it will cause a problem. There are three plugs that I can see in this picture, on the passenger side of the trans just above the pan. Is there any reason why I can't use one of these for the sensor?
Old Jun 11, 2012 | 06:05 PM
Smarty=Cummins's Avatar
The edge cts says to put it in the back one.
Old Jun 11, 2012 | 06:48 PM
JBearSVT's Avatar
Cool, thanks!
Old Jun 13, 2012 | 03:53 PM
gyayo2012's Avatar
I put mine in the back one, Its worked fine for me so far!.
Old Jun 14, 2012 | 07:09 AM
JBearSVT's Avatar
Excellent. Hopefully I'll get these hooked up this afternoon.
Old Jun 14, 2012 | 10:23 AM
1AMatt's Avatar
Site Sponsor - 1aauto
I see a lot of people do it in the hot line coming from the trans... But I agree with you, i dont think i'd wanna do that
Old Jun 14, 2012 | 02:22 PM
Smokey Freedom's Avatar
I've done both when doing gauges on customer trucks BUT going into a case plug makes the gauge slower to respond compared to being directly in the flow and if your cooler plugs I doubt it will respond fast enough for you to save your trans but then again by that point youre basically shafted anyway. Both work tho
Old Jun 14, 2012 | 04:40 PM
JBearSVT's Avatar
Is there even fluid that high up in the trans? I mean, that's several inches higher than the top of the pan.
Old Jun 14, 2012 | 04:45 PM
RAW's Avatar
RAW
Have a look at this:
https://www.dieselbombers.com/94-98-...-location.html
Old Jun 14, 2012 | 05:01 PM
JBearSVT's Avatar
That appears to be the first circled one from the left in my picture above. I assumed by "the back one" that was the one everyone has been talking about?
