mystery peice in the oil pump?
Old Jun 8, 2012 | 06:40 AM
rbpower's Avatar
Default mystery peice in the oil pump?
found this in the oilpump on one of my F550's maby a nidelbearing or a pice of wire? can anyone ID it... backgroung on the truck is 200k 06 F550 I bought it as a non running truck the old owner was just tired of the problems. when I got there was no oil pressure at all .found it last night on taredown. I was going to put a uesd gear and grease it up to get it to prime and see it another problem is there. if no other problems are heard, should I just pull the front cover look in the pan for more parts wash out the pan and let it go?
Old Jun 8, 2012 | 09:41 AM
Mdub707's Avatar
Yikes. I think I'd be pulling the pan looking for more clues for sure. Would hate to see it go back together and have a similar issue in another 500 miles...
Bob might have some more insight for you...
Old Jun 8, 2012 | 09:16 PM
bobfbigman's Avatar
That is a needle bearing out of a roller lifter, good thing you found this now, a failed lifter can destroy one of these engines. you are goint to have to remove the heads to get the lifters out, good time to upgrade to studs since you are going to have them off, not the first time I've seen the same thing, although the others were worse and had done alot of damage.
b&hbiz
Sep 9, 2015 07:53 AM
southern dieselnorth zip
May 18, 2015 01:02 AM
Gm3500
May 7, 2015 11:01 AM
moneypitk5
Feb 12, 2015 11:01 AM
cjones980
Jan 25, 2015 11:58 AM
