6.0 powerstroke
Old Jun 5, 2012 | 02:26 PM
jkgoodwin02's Avatar
Default 6.0 powerstroke
Hey guys have a dumb question I have a 04 powerstroke and i just did head gaskets abd ifilled truck eith water and a cleaner if its just water will i the level drop slowly from it getting hot and evapurating
Old Jun 6, 2012 | 12:10 AM
bobfbigman's Avatar
It shouldn't, it might drop a little as the air is being removed because it was drained, most motors will settle at there own level, most of the time it is right at the min line wich is the new max line, if you degas bottle doesn't have a sticker put on it from the dealer then make sure you only fill to the min line. If you were pushing fluid out the cap because of a bad headgasket then it might be wise to replace the cap, seems pretty common once the caps purge alot they don't hold the proper presure anymore.
Old Jun 6, 2012 | 07:52 AM
Mdub707's Avatar
Ford says anytime a cap has pushed coolant to replace it. They're pretty cheap anyways. Napa sells one for like $5.
Old Jun 18, 2012 | 11:20 AM
I have another pronlem I been driving my truck for two weeks I drove it a hour away then on my way home my buddy was messing with me on his wrx and I punched it and fell on its face then wasnt running right when exceling
Old Jun 18, 2012 | 12:39 PM
Mdub707's Avatar
Going to need more info than that... did it clear up? Was it belching smoke, how were you driving it? Is this truck tuned? Is it still messed up or did it go away? Need more info here, not much to go on.
Old Jun 18, 2012 | 01:55 PM
I haven't driven it since it happened two mins from my house it's not tuned I just did head gaskets on it new oil cooler it has egr delete intake and exhaust I started it yesterday and it smelt like fuel when I started it but idles fine but when I rev it up it won't rev like usually I wasn't driving it hard I was driving normal and got on it pretty hard and let off
Old Jun 18, 2012 | 02:29 PM
Mdub707's Avatar
The fuel smell is normal on a cold started diesel, since it's not burning it all. It still wont rev up like normal? Have you tried driving it again? Opened the hood and looked around? Might have been something simple like a boot blown off the intercooler!?
Old Jun 18, 2012 | 02:47 PM
I looked I didn't see any off I was having that problem but looked fine do u think it could be the fuel filters they looked worn when I took them off when doing the heads
Old Jun 27, 2012 | 04:27 PM
I just checked ficm it's giving 48v and replaced the fuel filters and it still isn't running right I took it out again was ok for less then a mile then started acting up its running rough and when u give it gas it didn't go
Old Jun 27, 2012 | 07:33 PM
Lilpooh's Avatar
When you had the headgaskets done, did you send the heads to a machine shop to be checked?
Any codes?
What fuel/oil filter are you using?
What is your fuel pressure?
Is yours a early '04 or late '04?
http://napaautotech-classsupport.com...-TIPS-1WEB.pdf
