speedo problem 01 cummins
Old Jun 3, 2012 | 11:57 PM
mike12v!'s Avatar
Default speedo problem 01 cummins
where is the transmission speed sensor on a 01 cummins or what makes the speedo work?
Old Jun 4, 2012 | 07:02 AM
RAW's Avatar
RAW
There is a sensor in the rear differential that sends the speed signal.
Old Jun 10, 2012 | 07:12 PM
lunk's Avatar
sits on top the rear dif
Old Jun 10, 2012 | 09:12 PM
Jkirts379's Avatar
they r known to go out mine just went out. they sit right on top of the rear dif mine started actin up after i put a locker in it
Old Jun 11, 2012 | 03:17 PM
1AMatt's Avatar
Site Sponsor - 1aauto
X2 on the sensor in the diff... Very common prob
Old Jun 11, 2012 | 09:56 PM
luke46's Avatar
I've changed them on both 24v I've owned. But once I had my brakes get low and the abs light came on and it quit working? I fixed the brakes and it worked again. Not sure how but it is what it is.
Old Jun 12, 2012 | 06:47 AM
mike12v!'s Avatar
My abs light is also on
Old Jun 12, 2012 | 10:12 PM
luke46's Avatar
If it were me I would order the sensor they are thirty bucks or so, then check other stuff they are a common problem. Also had the wire coming out of the plug lose the connection once.
Old Jul 6, 2012 | 11:41 PM
cincolatham11's Avatar
I pulled mine just a little while ago and went to price them online and it looks different mine is a cylinder connected to a plug and there is small copper wire wrapped around the cylinder. All the pictures online have a case over that. My question is. Does that case just serve as protection till you put it in the truck or is the other half of mine still shoved in the rear end.
burndiesel
10
Feb 7, 2023 01:15 AM
Antwhite19
Mar 26, 2020 04:58 PM
Jonrarick
Oct 25, 2016 01:32 PM
jeremy01995
Sep 14, 2015 06:34 PM
signoremint
13
Oct 21, 2014 07:21 PM
