Smarty Question
Old Feb 17, 2008 | 07:22 PM
uawelder322's Avatar
Default Smarty Question
I recently bought a Smarty for my 06 5.9. I was wondering if Smarty has any other downloads that are'nt in it already. Thanks
Old Feb 17, 2008 | 07:36 PM
jstange2's Avatar
Go to MADS Electronics - Smarty - CaTCHER - DLWelcome the first click here is for if you have stock turbo and injectors. The second click here is everything else. You can run the aftermarket turbo/stock injectors with a stock turbo (adds boost fooler). I went from 30psi to 36psi when I switched to this tune. The torque management is how fast the motor is allowed to make the torque. Stock is the least (safest for tranny). Wild is the most (kill stock tranny quickly). Hope this helps.
Josh
Old Feb 17, 2008 | 08:27 PM
If i download a program does it become another number on the Smarty? And is it hard to download?
Old Feb 17, 2008 | 08:35 PM
jstange2's Avatar
With the Smarty, you actually erase the current programming on the Smarty, and a new version of your choosing is programmed back onto the Smarty. The first time you do it, it seems like you should have went to school for 20 years to become a super computer designer, but after that it is pretty simple. Depending which version came with yours, you may even get a couple extra features with an update like fast idle and adjustable speed limiter (if you don't already have it). I will send you a link with some pictures of the process to update.
Josh
Old Feb 17, 2008 | 08:55 PM
Wow,that looks very hard!!!!!!!!!!! Is it really worth it?
Old Feb 17, 2008 | 09:10 PM
jstange2's Avatar
OOOOOOHHHHHHHH YYYEEEEEEEEAAAAAAAHHHHHHHHHH!!!!!!!!!!!
The tune I'm running now is VERY powerful. I love it, and the egt's barely touch 1300*. With the oct tune, I would hit 1500* by 70 mph when playing, but man did it smoke. I like to do something different sometimes though.
It is waaayyyyy easier after you have done it once. When you plug in the smarty, what version does it say you have? You may not have to update anyway.
Josh
Old Feb 17, 2008 | 09:25 PM
Josh
I'll let you know tomorrow when I plug it in! For now I'm off to bed! Thanks for all your help so far!
Old Feb 17, 2008 | 09:27 PM
jstange2's Avatar
Not a problem man.
Josh
Old Feb 18, 2008 | 07:48 PM
My Smarty says V:4.11B D:2.11A 2004-2007 when I plug it in!
Anyone with advice please help!
Last edited by uawelder322; Feb 18, 2008 at 07:48 PM. Reason: Automerged Doublepost
Old Feb 19, 2008 | 07:11 AM
jstange2's Avatar
I think that you have the most recent december update with mild torque management. They way that the 4.11 software is more powerful than the beta. You should be set.
Josh
