View Poll Results: What diesel should I use ?
Powerstroke 7.3
0%
Cummins 5.9 12 Valve
50.00%
Powerstroke 6.4
50.00%
Voters: 2. You may not vote on this poll
new diesel for my 93 bronco
Old May 31, 2012 | 12:24 PM
samsbronco's Avatar
Default new diesel for my 93 bronco
Ok my E4od died the other day in dallas and I was looking at doing a ZF5 swap and have found two truck's on craigslist that have been wrecked first and the one I am kinda wanting more is the 95 F-350 4x4 with a 7.3 5 speed and 115K I think it will be almost bolt in and I have found a 93 12V cummins its a 2wd but it only has 56K and a auto and the one that would be bad *** the company my dad works for had a guy roll a 2010 F350 4x4 auto with 27K it would be fun as hell and the one I would prefer if I thought I could pull it off but the 5.9 or the 7.3 I will use a ZF5 trans since there is not much room under it I will probably have to use my t-case and I think I may not have to deal with too much drive line issues and put in 1 ton axles and a lift not much just want to run about a 35 I want to get the axles off of a 93 so they maybe they bolt in at least that's what I am thinking since everything should be in the same spot maybe ? i was just thinking my 351 has 245k on it and this is my second trans and i have been babying it since i got it I do mostly highway driving and used to pull trailers with it un till the first trans went out I think the diesel will also get better mileage than the gas I am only getting 11 on the hwy so what do y'all think Cummins or Powerstroke,Sam
Old Jun 30, 2012 | 08:11 AM
allen2289's Avatar
Cummins
Old Jun 30, 2012 | 08:58 AM
samsbronco's Avatar
decided to put in the 7.3 powerstroke it was pretty easy almost bolt in I did swap the whole wiring harness but that was not too bad the hardest part was swapping the axles for the sas swap I used axles off a 99 superduty with 4.10 gears and used the spring hangers off the 95 and I decided to run a set of 37 12.50 R17's it looks good and is there any good upgrades to do while I still have the front clip off ??? Thanks,Sam
Old Jun 30, 2012 | 09:24 AM
ToMang07's Avatar
Nice!
Only things I can think of that I would do with the front clip off would be LPOP (Melling) and a new Waterpump. Much easier that way. If you do a new WP, I'd do a Coolant filter setup, too. What year engine did you use?
Old Jun 30, 2012 | 10:05 AM
samsbronco's Avatar
used the 95 7.3 and ZF5 and the bronco t-case kinda got stuck with that one there is not much room under the bronco
Old Jun 30, 2012 | 10:29 AM
ToMang07's Avatar
Nice...you have forged rods then. Might be worth looking into a 17* or modded HPOP too, E-Fuel would be beneficial as well. Any plans to tune it, injectors, turbo, etc?
Could be a monster Bronco, that's for sure!
Old Jun 30, 2012 | 11:13 AM
samsbronco's Avatar
I am gonna keep it close to stock for now till i put a few miles on it but it has a 5in exhaust and a cold air intake and a performance clutch but its still waiting to get it painted and with the way I work I drive my duramaxx more than any thing 15 days on and 5 off so I have limited time to work on it but Hope fully I will have it done by august Thanks for the help
Jet A Fuel
6.7 Liter Dodge Cummins 2013+
8
Oct 21, 2015 03:30 PM
Jet A Fuel
Aug 3, 2015 10:45 AM
Strictly Diesel
Strictly Diesel
Jun 30, 2015 06:48 PM
Mar 18, 2015 07:30 PM
wolfnexus
Nov 4, 2014 10:04 PM
