05 ford 6.0l rebuild
Old May 29, 2012 | 10:24 PM
fixorepair's Avatar
Default 05 ford 6.0l rebuild
Where can i find the specs for the crankshaft and cam before I send the block to the machine shop also need specs for the cyl bore
where would be a good place to get cam and lifters
Last edited by fixorepair; May 29, 2012 at 10:24 PM. Reason: Automerged Doublepost
Old May 29, 2012 | 10:29 PM
Mdub707's Avatar
Cam and lifters? I know an aftermarket cam is right around 600 but bit sure what factory lifters run. What the heck happened?
Old May 30, 2012 | 04:38 PM
TheRobenator's Avatar
I am sure you can call you local diesel shop and ask for the specs as far as torque and clearance are concerned.
Old May 30, 2012 | 06:50 PM
fixorepair's Avatar
well after all the trouble in and out of shop we thought we had it fixed with a new oil cooler and IPR drove from Oh to WV and back then it shut off with low oil pressure again they pulled the lpop and it was shot along with front cover. Dropped the oil pan found parts of piston rings, While I was Lifting engine out little ball bearing were hitting the floor not sure where those came from. stripped engine #8 cyl compression ring was gone 2nd ring wore to nothing oil ring gone piston beat to hell and back. But prertty sure I can save the block, crank is ok and cam and lifter look alright just dont know if I want to chance them after having engine down this far.
Old May 31, 2012 | 01:32 AM
bobfbigman's Avatar
If they were little needle bearings then it was a lifter that failed, I saw onther motor this happened to and it wiped the cam lobe off. make sure you mark the crank adapter on the back of motor before you pull it off, has to be removed to get cam out, it is heated and pressed on before the crank is balanced so make sure to stamp it or something.
Old May 31, 2012 | 07:11 PM
fixorepair's Avatar
not needle bearings but little ball bearings
Old Jun 1, 2012 | 04:11 AM
bobfbigman's Avatar
those bearings were probably from an idler pulley or ac pump pulley
Old Jun 1, 2012 | 09:10 AM
Mdub707's Avatar
If you're replacing the cam anyways, put an aftermarket one in. Colt cams are $599.
makuloco2000
Feb 15, 2015 02:31 PM
tbreddiesel
Thoroughbred Diesel
Jan 12, 2015 02:23 PM
Dec 10, 2014 08:10 AM
Oct 13, 2014 08:10 AM
