Tach will not read
Old May 27, 2012 | 12:33 PM
Deeres&Dodges's Avatar
Default Tach will not read
Checked as many connections as I can find, short of pulling the gauge cluster out. Spacing on the sensor to harmonic balancer is .020 as it should be. How does the sensor work? Is it a magnetic pickup in the balancer? Truck has been parked for about 3 years and I just acquired it. There are a few eletrical issues that I have already worked through, but this one has me stuck. Also, I found that with key off, there is a power draw on the fuel pump fuse on the drivers side fender fuse box. If I leave the fuse in, the batteries will be dead in about 20 hrs. Can't find any shorts in the wires. What does this fuse power? Any one have a good wiring schematic?
Old May 27, 2012 | 12:39 PM
cummin_un_glued's Avatar
FormerVendor
the crank sensor is a mag pickup so maybe sand any rust off of the balancer if not then try another sensor, idk on the fuse
Old May 28, 2012 | 10:06 PM
Sanded the balancer clean. How do I test the sensor? I would rather not just start throwing parts at it.
Old May 29, 2012 | 12:01 AM
FormerVendor
only way i know to test the sensor is to replace it sorry man
Old May 29, 2012 | 04:33 PM
1AMatt's Avatar
Site Sponsor - 1aauto
Check a Haynes or Chilton manual... Everything electrical should have some sort of specification! Or maybe someone has access to Alldata
Old Jun 2, 2012 | 09:20 PM
Replaced sensor and still no tach. I think that the wait to start light is also not working. Hard to know for sure as it was 80 today. Any other thoughts?
Old Jun 5, 2012 | 01:19 AM
flatbedr's Avatar
if u have power at the sensor. checked all the fuses i would pull cluster an see if it is corodid or burnt up. white powdery stuff is bad if it was sitting for along time rats could also b a issue. is there any other sign something was living in it?
Old Jun 5, 2012 | 06:42 AM
No signs of critters. It was stored inside the shop. I do have power to the senor, and I do have a good ground. I had the cluster out and found small amount of corrosion on the terminals. Cleaned with eletrical contact cleaner and brushed them clean. The only thing that I have not been able to find is were the sensor goes between the crank and the dash. I don't want to cut open the wire loom if I don't have to. Still looking for a good complete wiring schematic.
Old Jun 10, 2012 | 01:24 PM
Brought the truck to paint yesterday and lost the speedometer and odometer on the way. I am thinking I have a bad connection somewhere. Looks like I will be chasing a Gremlin.
Old Jun 19, 2012 | 07:04 PM
Smokey Freedom's Avatar
Had a bad ground for the cluster do similar stuff once but was all or nothing. Im betting its in the dash tho
Last edited by Smokey Freedom; Jun 19, 2012 at 07:04 PM. Reason: Automerged Doublepost
al0311
Mar 8, 2016 05:52 AM
tur370
May 17, 2015 04:00 PM
tur370
May 14, 2015 08:09 PM
gp98
Apr 1, 2015 07:08 AM
short12
Jan 2, 2015 04:56 PM
