Duramax all aluminum radiator
Old May 27, 2012 | 12:40 AM
2004LB7's Avatar
Default Duramax all aluminum radiator
as the title states. is there such a thing? been searching around for a radiator without the plastic end caps. mine has developed a leak around the seam and i have been topping it off about once a week. lately i am needing to top it off every other day. at some point enough is enough.
i would like to replace it with one that doesn't contain plastic in its construction. ie: aluminum end caps
anyone have any ideas on who may sell one of these? i have seen universal ones but the hose connections seem to be in the wrong place.
my truck is an 04 chevy 2500HD LB7 engine
thanks for any leads
Old May 27, 2012 | 01:07 AM
RanchhandTCR's Avatar
You can have a radiator shop build one for you mine is all sheet metal.. but even then they can still crack...
Old Jul 15, 2012 | 07:41 PM
2004LB7's Avatar
well, i decided to repair mine instead.
here are some photos of how i fixed it. seems to be holding up well so far.
area where it was leaking
prying tabs with a screwdriver
bending the tabs out the rest of the way
paying it open
tank removed. you can see the transmission "cooler" inside
remove gasket
after cleaning up everything, letting it dry in the sun
now for the reassembly. first a bead of black ATV
Gasket and another bead of ATV
now bend the tabs back down. i also tapped them flat with a small hammer
all done
its been about a month and still no leaks. everything seems good
Old Jul 17, 2012 | 10:25 AM
1AMatt's Avatar
Site Sponsor - 1aauto
Nice job. Great pics too
jt19
Aug 20, 2015 12:18 AM
Jul 28, 2015 12:40 PM
jt19
Jul 13, 2015 03:06 PM
Mar 13, 2015 03:40 PM
duramaxtuner
Dec 10, 2014 01:24 PM
