1996 fender replacement
Old May 27, 2012 | 06:30 AM
untill62's Avatar
Default 1996 fender replacement
I discovered that the inner fender liner is tack welded to the fender. what a pain. I am going to buy new liners I think. Can't I use some panel bond adhesive and a few nuts and bolts to fasten the two together. I see no reason it shouldn't work. Any thoughts?
Thanks so much for you help.
I forgot to add, that I would think welding would be best, but I don't have a welder, just one of the things on my list. Lot of rust on the old liner, so thought I would replace them also. 96 cummins.
Old May 27, 2012 | 03:56 PM
tiremann9669's Avatar
If you can find a rust free original from a southern parts dealer it will already have the inner and will probably be a better quality fender than an aftermarket.
Old May 27, 2012 | 06:30 PM
untill62's Avatar
Thanks, I already bought the fenders and I tried the drivers side. It doesn' fit bad and hopefully I can get it better. I think I will try bolting and panel adhesive if I can. I bought a tack weld removal tool and it worked on the old one, but the rust made me decide to order the fender well liner.
Old May 27, 2012 | 10:24 PM
If not I'm sure you can find someone to tack it together for a few bucks.
Old May 28, 2012 | 12:44 AM
huricane's Avatar
line her up drill holes then use sheet metal screws it works
Old May 28, 2012 | 07:36 AM
untill62's Avatar
thanks, I think the concern may be that the fenderwell supports a lot of stuff on the inside, battery and a lot of electrical. So I need to make sure it secured enough.
rajdiesel
Mar 14, 2015 07:11 AM
carid
Diesel Bombers Sponsors
Feb 9, 2015 07:12 AM
