How can i lower my boost
Old May 26, 2012 | 06:31 PM
iceman1404's Avatar
Default How can i lower my boost
Just bought a tst powermax3 and got it all hooked up. went to try it out and my boost spooled to 50lbs and fast. what can i do to it not to go past 40psi? Turbo is a hx35/40
Old May 26, 2012 | 06:40 PM
empty wallet's Avatar
boost elbow? whats wrong with 50psi?
Old May 26, 2012 | 08:28 PM
iceman1404's Avatar
Id love to keep it a 50psi but i got stock studs and from what i have researched to hx35/40 is rated to 40psi max
is it possible that i can lengthen the rod on the wastegate to start to release pressure at 40psi?
So getting my wastegate to open sooner than it is it would save me from grenading my turbo? and if so how do i do it?
Last edited by iceman1404; May 26, 2012 at 08:28 PM. Reason: Automerged Doublepost
Old May 26, 2012 | 08:41 PM
Benjamin's Avatar
Bombardier
yes, taking some of the preload off the wastegate actuator rod can lower the total boost, you may have to go and check all of the hose connecting to the wastegate actuator and make sure there are no holes and it is connected to the actuator and not bleeding off boost and prohibiting the wastegate from opening.
if all else fails, use less right foot, that will lower the boost ALL the time....
Old May 26, 2012 | 08:53 PM
iceman1404's Avatar
Yea i have been trying to watch my gauge and letting off but it spools so quick to 50psi. and then it surges eveytime i end up letting off it to quick trying to quickly bang into another gear fast. Id just like to get the boost lower where i could hold boost throughout the rpm range without it climbing so high
Even with the wastegate working properly could it just not handle the exhaust flow with the additional fuel?
Last edited by iceman1404; May 26, 2012 at 08:53 PM. Reason: Automerged Doublepost
Old May 26, 2012 | 08:56 PM
Benjamin's Avatar
Bombardier
ya you might have too much fuel for that snail...... you could open it up and do some porting to the wastegate hole in the exhaust housing, they leave a lot to be desired. I have also heard of people cutting the divider out either on the turbo or the manifold so that the wastegate would regulate all 6 cyls and not just the back 3.
Old May 26, 2012 | 09:05 PM
iceman1404's Avatar
even before the tst i was hitting 38psi pretty easily with just my smarty. probably the best solution to this problem would just to get a turbo that is rated for lets say for 60psi? the tst is just plain mean it just fuels so hard even on level 4 on it the turbo goes crazy
cutting the divider out on both the turbo and manifold would probably be very beneficial? Can you take to much off the wastegate hole or would it be a better idea to take a little out at a time put it back on the truck and try it?
Last edited by iceman1404; May 26, 2012 at 09:05 PM. Reason: Automerged Doublepost
Old May 27, 2012 | 01:57 AM
dukeboy_318's Avatar
You can also open up the boost elbow that came with the TST kit, they are adjustable. or put the factory one back in.
Old May 27, 2012 | 02:07 AM
iceman1404's Avatar
It didnt come with one. if i drilled out the hole in the elbow bigger would that help any? Or like stated before between the tst and the smarty is there just to much fuel and air being rushed into the turbo more than the wastegate can bleed out because it is to small? or is there a few things i can try before i port out the wastegate hole and the dividers. before the tst i was at a steady 38-40psi at wot now it will rocket to 45-50psi 3/4 throttle if im not paying attention
Old May 27, 2012 | 09:04 PM
Benjamin's Avatar
Bombardier
the boost elbow should have an allen set screw in it, back the screw out to lower the boost, screw it in to get more boost.
on the divider, I would do one or the other, some guys use a drill and drill some holes in it, some use a grinder to get a chunk out of it. IF it is a stock manifold I wouldn't think twice about it, if it is an aftermarket 3 piece I would look to go other routes.
on the wastegate hole, the hole is significantly smaller than the flapper that covers it IF noone has already messed with it. some companies will have this ported and some won't. as long as you don't open the hole up to bigger than the flapper then you should be OK.
