New fuel solenoid won't pull up?
Old May 26, 2012 | 04:04 PM
Deeres&Dodges's Avatar
Default New fuel solenoid won't pull up?
I just replace my fuel solenoid and fire wall relay and it still won't start unless I pull it up manually. HELP!!!
Not getting power to solenoid when cranking. Disassembled and cleaned the contacts at starter(brown wire), small wire off battery terminal on drivers side and on the relay it conects to. Now what? Also, no tach. Charges just fine. Something is drawing power through the fuse box under the hood as well.(sparked when reconnected battery, traced to something in here).
Last edited by Deeres&Dodges; May 26, 2012 at 04:08 PM. Reason: Automerged Doublepost
Old May 26, 2012 | 05:12 PM
daveO's Avatar
I would check the relay itself.
Old May 26, 2012 | 05:26 PM
turbo2332's Avatar
blue wire where it connects to the driver side battery. check it for corrosion.
Old May 26, 2012 | 06:17 PM
I did both. I found the terminal on the starter that the brown wire attaches to was loose. I disassembled the starter and repaired the best I could. Now it will start. I have a really good automotive electrical shop nearby and will have him make a more professional repair. I don't want to have to replace the starter just because there was a loose terminal.
Dbleo351
Nov 20, 2016 09:34 AM
Jet A Fuel
Tech Article Submission
Jun 5, 2015 03:28 PM
ctjkelley
Jun 3, 2015 06:01 AM
robbyS
Apr 16, 2015 02:22 PM
moneypitk5
Feb 12, 2015 11:01 AM
