Really confused
Old May 24, 2012 | 04:38 PM
maverickxxx's Avatar
Default Really confused
Okay so I put new injector in a few weeks ago trucks been running good an last few days been sluggish an low power smoke like when erg cooler went. Well I stalled it out still does hot no start sometimes. Well after jump starting it it was alive like really alive idt it even had that much power brand new. The draw back was won't idle just stalls when Rpms drop so I almost got it to my moms house closest place. Any ideas? Oh it seems as if some govenrn or something broke or some green emissions part broke an can run
Oh I also noticed the turbo really didn't need to wrk. The engine seemed to be running very very well except for couldn't low idle
I went back an started it an went back to way it used to be. I'm curious as to what wasn't wrking right to give it way more horsepower.
Last edited by maverickxxx; May 24, 2012 at 04:38 PM. Reason: Automerged Doublepost
Old May 25, 2012 | 12:15 AM
jeffa6980's Avatar
What mods are done to the truck?
Old May 25, 2012 | 08:51 AM
Mdub707's Avatar
Sounds like a high pressure oil leak to me.
Old May 25, 2012 | 04:31 PM
I was thinking that oil pump needs to be dun I went back after awhile n started back up n run crappy. I'm gonna pull erg valve an try n clean it. Maybe TOMMROW but I've been sick n sick for like two weeks so hoping antibiotics will get me to a decnt energy level.
No mods
Last edited by maverickxxx; May 25, 2012 at 04:31 PM. Reason: Automerged Doublepost
Old May 26, 2012 | 12:31 AM
bobfbigman's Avatar
When you put the new injectors in did you install new standpipes? they are not supposed to be reused once taken apart. Also have you put the new style dummy plugs in too? If not might want to get the kit that comes with the dummy plugs and standpipes.
Old May 29, 2012 | 11:48 AM
So where should I get new high pressure oil pump?
No I didn't replace drain tube n dummy plugs
They are uPgraded ones.
Last edited by maverickxxx; May 29, 2012 at 11:48 AM. Reason: Automerged Doublepost
Old May 29, 2012 | 12:09 PM
Mdub707's Avatar
Ok after re-reading this and what you're telling me now, I'm not sure it's a high pressure leak.
I would get it on a scanner and monitor ICP desired and ICP actual, as well as IPR % duty cycle. There is no point guessing at what is going on when we can just eliminate it or narrow it down with a scanner.
Old May 31, 2012 | 03:36 PM
Cleaned egr valve was sticking cleared smoke up now does randomly at low idle
brodey
Mar 29, 2015 12:12 PM
