clutch pedal squeaks all the damn time
Old May 23, 2012 | 06:40 PM
dochawken's Avatar
Default clutch pedal squeaks all the damn time
Have lubed the small piston that enters the cylinder near the fire wall but no change, worse when I let off on the cluthc pedal than when I depress it. Just annoying as hell....maybe the hydraulic system is worn out?? Any ideas?? Doc
Old May 23, 2012 | 07:50 PM
ricet07's Avatar
Look above that piston way at the top where the pedal pivots, probably a little bushing worn out. Just shoot some lube up there and see if that fixes or at least you will know what your problem is.
Old May 24, 2012 | 12:17 PM
1AMatt's Avatar
Site Sponsor - 1aauto
WD40 does wonders
Old May 26, 2012 | 08:14 AM
Crosscut's Avatar
Don't let it go too long! I ended up having to replace the pivot pin & mounting bracket for the pedals. The plastic wear sleaves the pedals rotate on leave much to be desired. An actual bearing assembly for the pedal pivot pin would be a major improvement.
Old May 27, 2012 | 08:04 PM
cruisin blackjack's Avatar
mine did that for the first year and a half i had my truck. got new clutch and still did it..sprayed WD40 and all..nothing..and eventually it just quit doing it, no problems yet haha
Old Jun 6, 2012 | 06:47 PM
98CumminsPower's Avatar
wd40 mine does that in the mornings ever few weeks.
Old Jun 28, 2012 | 11:58 AM
photomonkey's Avatar
I thought mine was the only one...
super annoying
ILLUSHA
Diesel Engine Conversions
10
Aug 21, 2015 05:48 AM
Turbo67
Jul 25, 2015 02:26 PM
lkfldredneck
Jun 25, 2015 04:51 PM
SixSpeed
Jan 11, 2015 01:41 AM
