Warped oil cooler?
Old May 23, 2012 | 12:53 PM
Elementalg20's Avatar
Default Warped oil cooler?
Getting to the bottom of things and wanted to make sure I shared this. I did a HG job, lots of head work and had the oil cooler checked for leaks(pressure checked). I had water pouring into my oil after reassembly....took the oil cooler off hoping to find something.
Sure enough, the cooler and the housing both are warped to hell. Is this common at all? Anyone heard of it? I got new gaskets(again) and a new oil cooler coming, had the housing milled down just a touch to fix it and we'll give her another go!
Old May 23, 2012 | 08:03 PM
welderboy250's Avatar
Never heard of it before but I've seen stranger things
Old May 26, 2012 | 05:25 PM
Should have asked originally, does anyone have the torque specs and sequence for the oil cooler? Thanks!
Old Jun 2, 2012 | 04:36 PM
Just wanted to update, this is likely a one in a million but I did buy a new cooler after having a machine shop confirm what I was already sure of. Mine was somehow bent/warped along with the filter housing. They were able to mill the filter housing just a little so I could reuse it, and I purchased a new cooler and gaskets. Problem thus far solved.
Crabber0001
6.0L Performance
Aug 4, 2015 12:30 PM
tim12valve
May 6, 2015 10:40 PM
Bighouse
Apr 9, 2015 06:51 PM
emilio2496
8
Jan 13, 2015 05:03 PM
bypass-21
Dec 15, 2014 08:52 AM
