Poly Performance Visit - Poly Performance
Dodge HD Suspension & Steering Specials! Shocking Actually....
Old May 23, 2012 | 11:17 AM
PolyPerformance's Avatar
FormerVendor
Default Dodge HD Suspension & Steering Specials! Shocking Actually....
Hey guys,
We've recently expanded our Dodge HD lineup of suspension and steering products from Synergy Suspension and FOX. Don't forget we are also a dealer for Carli, ICON, Rough Country, CST and many, many other brands!
Feel free to PM/ EMAIL me for pricing / availability on anything 4x4 related!
FOX has recently released their " Performance Series IFP" Smooth Body shocks in many common sizes, these are awesome shocks with an aluminum body starting at $127
Description:
The 2.0 Performance Series Shocks delivers race-dominating performance in a hassle free bolt-on package. Their heat-reducing design includes a metal-impacted aluminum shock body that dissipates heat faster than conventional steel. Inside the Internal Floating Piston (IFP) separates shock oil from a high-pressure nitrogen gas chamber that provides a predicable ride quality capable of handling the roughest road conditions. Combine these new technologies with a competitive price for a winning combination.
Specifications:
Body - Aluminum shock body dissipates heat three times faster than steel.
Components - Black anodized 6061-T6 billet aluminum
Shaft - 5/8" hard chrome plated heat treated alloy steel
Piston - Race-developed high-flow piston design
Valving - Application specific valving to maximize offroad performance
Seals - Redundant sealing pack system main seal, wiper seal, scraper seal
Oil - Specially formulated for ultimate performance at variable temperatures
Reservoir - Internal reservoir design separates shock oil from the high-pressure nitrogen
Mounting - Applications available for stock and aftermarket lifts kits
Adjustments:
Rebuildable
Nitrogen pressure
Compression valving
Rebound valving
We also stock most of the 2.0 FACTORY Series shocks as well, these are the original Fox smooth body shocks that have proven themselves year after year in some of the harshest applications on the planet.
These start at $165. The Factory series can also be had with a remote reservoir starting at $220. The reservoir adds additional fluid which helps keep the shock cooler, not to mention the reservoir can add some nice "flair" to your rig.
Fox has recently released a compression adjuster option for the remote reservoirs as well, this will run you $120 more and give you 8 clicks of compression adjustment. This is a killer idea for that multi-purpose DD or the tow rig that doubles as a DD. You can back off the adjusters for normal street driving and ramp up the compression for towing or hauling heavier loads.
SYNERGY SUSPENSION Components:
Synergy Suspension Front Lift Coil Springs for 94-Present Dodge 1500, 2500, 3500 Starting at $250
Description:
Front lift coils for Dodge 1500 Mega Cab 4x4 & 2500/3500 trucks
Synergy Suspension coils offer excellent off road performance while preserving ride quality
Progressively wound; keeps spring from coming unbound at suspension droop
Progressively wound spring eliminates annoying spring clanking found on most suspension kits
Feature frequency balanced and tuned spring rates to maximize suspension performance on and off road
Suspension components feature an abrasive-resistant black powder coat finish for maximum durability and corrosion resistance
Springs are designed to give the advertised amount of lift with use of aftermarket front bumpers & winches.
Sold in Pairs
Notes: When using stock Dodge wheels, we recommend a 1-1/2" Bolt-On Wheel Spacer
Synergy Suspension Dodge Truck Front Coil Spring Spacer Lifts Starting at $130
Description:
High Density Progressive Polyurethane
Lifts Vehicles Without Sacrificing Ride Quality or Load-Carrying Capacity
Easiest Way to Add 20"-22" Wheels and Increase Ground Clearance
No Metal-on-Metal Contact as with Other Leveling Kits
Lifts the front of the vehicle to level the stance
Sold in pairs
Synergy Suspension 94-11 Dodge 4X4 Steering Box Brace 4WD 1500, 2500, 3500 Starting at $155
Description:
Synergy Suspension Dodge Steering Box Braces
Designed to support the steering box sector shaft on 1994-2011 Dodge 4x4 solid front axle trucks
Ties front frame horns together, helps eliminate steering box "wander"
Tightens up steering feel and extends the life of your truck's steering box
Laser cut, CNC bent and precision welded
Black powder coat finish for maximum corrosion resistance
100% Bolt-on installation. No cutting or drilling required!
Synergy Suspension Front Upper Control Arm Pair for 94-Present Dodge 2500/3500 4x4, 1500 Megacab 4x4- Starting at $425 ( We have Adj Lowers too!)
Description:
Application:
94-Up 1500 Megacab/2500/3500 4x4
Features:
Suspension components feature an abrasiveresistant powder coat finish for maximum durability and corrosion resistance
Made from high quality crush resistant 1 1/2" X .156" Wall 1026 DOM tubing
Incorporates the tried and true Currie Enterprises Johnny Joints® for paramount performance
Synergy Suspension Double Adjuster Sleeve & Pinch Bolt Assembly: allows for adjustment of control arm length without removing control arm mounting bolt
100% bolt on components assures an easy, trouble free installation with the use of basic hand tools
1994 to present, requires drilling of mounts to 9/16'' on 94 to 99 models
Sold in pairs
Synergy Suspension 94-2011 Dodge 2500/3500 4x4, 1500 Mega Cab 4x4 Adjustable Track Bar- Starting at $270
Description:
03-11 2500/3500 & 1500 Mega Cab 4X4
94-02 1500 / 2500 / 3500 4x4 with Synergy late model track bar upgrade bracket (PPM-8554)
Note: 2000-2002 trucks with Y-style steering and axle mounted steering stabilizer, need 8550-02 Track Bar
Bent to clear most aftermarket differential covers
Retains factory track bar mounting bolts & hardware
Made from high quality 1-3/8" 1045 Solid tubing
Allows centering of front axle when running a suspension lift
Suspension components feature an abrasive resistant powder coat finish for maximum durability and corrosion resistance
FK Bearing heavy duty heat treated 7/8" chromoly rod end at axle end
Synergy Suspension double adjuster sleeve & pinch bolt assembly allows for adjustment of track bar length without removing control arm mounting bolt
Synergy Suspension 94-02 Dodge Track-Bar Conversion Bracket Starting at $175
Description:
Synergy Suspension Dodge Track-Bar Conversion Bracket for 94-02 4x4 trucks
Eliminates the weak link in the otherwise stout 4x4 Dodge chassis which has been plagued for years due to its poor track-bar design
Converts the stock ball-joint style TB to the newer 03-current bushing style track-bar
Designed to work with Synergy Suspension Adjustable Track-Bar (PPM-8550)
Tightens up steering and suspension feel and helps eliminate dreaded "Death Wobble"
Grey powder coat finish for maximum corrosion resistance
Bolt on installation
EMAIL / PM for SPECIAL BOMBERS PRICING!
FormerVendor
OR put it all together and go for one of the starter kits! PM with a shipping zip code for special Bombers Pricing!
Synergy Suspension 94-Present Dodge 1500/2500/3500 4X4 3" Starter Kit -Starting at $540
Description:
Engineered and manufactured in the U.S.A; the Starter System is available for all 1994 and newer Dodge 1500/2500/3500 4×4 trucks and will lift the truck 3.0". The Synergy Starter Suspension System accommodates up to 37" tall tires.
Features:
Front adjustable track bar and optional early model trackbar retrofit bracket
Synergy Suspension double adjuster sleeve & pinch bolt assembly allows for easy adjustment of trackbar without removal
Heavy duty sway-bar links for the correct swaybar geometry and maximized stability
Progressive wound coil spring manufactured using the latest in CNC hot winding technology for optimized on and off road performance
Heavy duty rear shackles provide a minimal amount of lift while keeping the rear driveline angles correct
Each suspension component features an abrasive-resistant powder coat finish for maximum durability and corrosion resistance
Kit Includes:
PPM-8515 - Synergy Suspension Front Swaybar Links
PPM-8555 - Synergy Suspension Front 3.0" Coil Springs
PPM-8566 - Synergy Suspension 1.0" Lift rear Shackles
Options:
PPM-8550-01/02 - Synergy Suspension 94-11 Dodge 2500/3500 4x4, 1500 Mega Cab 4x4 Adjustable Track Bar**
PPM-8551 - Synergy Suspension Adjustable Length Replacement Front Lower Control Arms
PPM-8554 - Synergy Suspension 94-02 Late Model Trackbar Conversion Bracket*
PPM-8563 - Synergy Suspension Fixed Length Replacement Front Lower Control Arms
Shock Options:
FOX-980-24-942 - Fox IFP Front Shocks
FOX-980-24-943 - Fox IFP Rear Shocks
FOX-980-24-944 - Fox Front Remote Reservoir Shocks
FOX-980-24-945 - Fox Rear Remote Reservoir Shocks
Here is a link to our Dodge suspension page, don't forget we are a Carli, Rough Country, ICON, RCD, and CST dealer as well!
Poly Performance JEEP/TRUCK & BUGGY*::*Suspension*::*Suspension & Lift Kits*::*Dodge Suspension Systems*::*Synergy Suspension - 4X4 Off-Road Parts, JK Synergy Suspension Systems, Fox Racing Shox, Beard, CNC Brakes, Johnny Joints®, Currie Enterprises,
EMAIL/ PM for PRICING & AVAILABILITY!
Old Feb 17, 2013 | 11:52 AM
cuda620's Avatar
Default susp
I'm interested in your pricing on a performance 2.0 and a backcountry 2.0 suspension for my 98 dodge 2500 4x4 QCSB. I'll need a track bar bracket too. I believe the Carli kits come with the bars but no bracket. The "synergy ones look just like the BD ones that I've installed in my shop in the past. Is that so? Thanks May as well quote me the sterring box/frame support while you're at it. I may make my own,depends on cost.
carid
Diesel Bombers Sponsors
Apr 22, 2015 09:28 AM
BubbaDT55
Apr 12, 2015 10:47 PM
Dec 12, 2014 12:30 PM
Nov 3, 2014 08:10 AM
