over flow valve questions?
Old May 22, 2012 | 09:52 PM
tmonroe's Avatar
Default over flow valve questions?
Will i see any gains by adding a over flow valve and runing about 30 psi with a boost elbow? If so how much
Old May 23, 2012 | 05:46 PM
tiremann9669's Avatar
You already have an OFV
Old May 23, 2012 | 06:16 PM
tmonroe's Avatar
A tork tech adgustable over flow valve
Old May 23, 2012 | 06:40 PM
Old May 23, 2012 | 07:45 PM
ricet07's Avatar
The OFV only controls the amount of pressure in the pump by "popping off" or bleeding fuel off back to the tank to maintain a certain pressure in the pump. Just replacing a perfectly fine OFV with an adjustable one will not give you more power. If you think you are loosing pressure then get a gauge and monitor it. Your focus should be else where if you have a fuel pressure issue, like lift pump or filter. Usually if your OFV is on its way out your truck will start a little harder than normal. You can stretch the stock spring or add a spring out of a bic pen to stiffen it up.
Old May 23, 2012 | 09:26 PM
tmonroe's Avatar
ricet07 I see u have procomp shocks do u feel they made a substantial improovment
Old May 23, 2012 | 10:49 PM
ricet07's Avatar
My old shocks were pretty bad so I would say yes. As far as comparing them to a new stock replacement I dont think there would be that big of a difference.
RA113024
Mar 13, 2016 07:42 PM
markv8993
Jun 21, 2015 12:24 AM
LTreis702
Feb 14, 2015 12:52 PM
12&24 Valve cummins
Nov 13, 2014 11:05 PM
Nov 12, 2014 08:10 AM
