Another about steering issues
Old May 21, 2012 | 05:14 PM
zach2's Avatar
Default Another about steering issues
I replaced upper and lower balljoints, tie-rods, steering stabilizer, track bar, and unit bearings back in March. Alignment done soon after. My question is why does the truck now require constant steering corrections as if it has "bump steer"? The ride, otherwise, is like new.
Old May 21, 2012 | 05:33 PM
JBearSVT's Avatar
It didn't do that before you changed all those parts?
Old May 21, 2012 | 05:57 PM
zach2's Avatar
I never noticed it before. I took it to have the alignment check and the shop showed me all of the worn out parts. It was a little rough riding, but no steering problems, oddly.
Old May 21, 2012 | 06:19 PM
Uncle Bubba's Avatar
Checkout the thread in my signature and see if anything in there helps out.
Old May 21, 2012 | 07:46 PM
zach2's Avatar
Thank you! What I found was that I havent changed any control arm bushings if that were needed and the shop torqued my hub/unit bearings to 280ft. lbs. instead of a suggestion in your post to torque them to 175lbs. Any concerns about that affecting my steering?
Old May 21, 2012 | 08:00 PM
Whit's Avatar
Site Mascot
sound like you need to be a touch more toe in on yer allignment, this will make it go straight without wander
Old May 21, 2012 | 08:11 PM
zach2's Avatar
Okay, thanks. I have been thinking of having the alignment checked again anyhow. It drives the same after the alignment as it did before I had it aligned from doing the work.
Old May 22, 2012 | 01:18 PM
Jason P's Avatar
been having steering issues also parts in front are all tight (if not I replaced) changed the steering shaft and bushing at the end of the steering column this morning and made a world of difference. Almost like new
Old May 22, 2012 | 08:10 PM
zach2's Avatar
Okay, thanks! May be a good suggestion too. I'm going to have the alignment checked tomorrow to be sure.
Old May 24, 2012 | 12:20 PM
1AMatt's Avatar
Site Sponsor - 1aauto
It could be your gearbox as well
dwmeehan
Jan 29, 2025 12:13 PM
Antwhite19
Aug 23, 2015 06:07 AM
ramrunner01
Jun 1, 2015 12:10 AM
BubbaDT55
Apr 12, 2015 10:47 PM
Polaris04
Dec 1, 2014 08:27 AM
