loosing boost codes p1693/1694
Old May 20, 2012 | 08:25 PM
knanabou's Avatar
Default loosing boost codes p1693/1694
2001 dodge ram 3500. just installed a jasper tranny. cold air intake.removed a diablo puck and a superchip programer. throttle position senor replaced 8 mo's aqo. f.a.s.s. lift pump
now rough idle morning starts with alot of black smoke until i get underway and press acc pedal down twice. when hit a bump in the road the turbo boost falls to half and rpms go to 1500. when i press the pedal up & down twice the turbo kicks in and boost goes to normal. one shop said the injection pump wiring harness is bad. another shop says it is the injection pump. i have only p1693/1694 codes. the mech found the same thing on his reader.dont know what to do.
Old May 20, 2012 | 08:38 PM
empty wallet's Avatar
Sounds like you're describing dead pedal, and you need an injection pump
Check the connection/plug at the vp44 and make sure everything is connected as it should be. Do you know fuel pressure? Pusher or aftermarket lift pump?
Old May 21, 2012 | 12:58 AM
knanabou's Avatar
dont know pressure.replaced a working lift pump with a fass pump a month ago. had the truck a year now and as far as i know, the lift pump always worked. someone cut off plug at injection pump and wirenutted it back. i thought that might be the problem. i will check the pressure. was hoping it is not inj.pump. bought this truck a year ago and spent more $ into the truck than i paid for it. thanks for your help.
where would be the best place to buy an injection pump
Old May 22, 2012 | 06:13 PM
knanabou's Avatar
truck at shop for injection pump
Un4givn
10
Apr 27, 2015 01:58 AM
stewart.william.c
Feb 11, 2015 01:39 AM
chaoticape
Jan 4, 2015 05:35 PM
ash23k
Dec 30, 2014 08:31 PM
Crews8r
Dec 21, 2014 07:35 AM
